Car won't start...HELP
So basically today i tried starting the car. right when i twisted the key, i heard this click sound, and now the car doesn't start. im pretty sure the battery is dead, but why would it be after just 40000 miles? is that normal? i can't even lock/unlock the car, lights won't turn on, and even the light on the roof doesn't come on when i open the door. if anybody can help me identity the problem, i would appreciate it. thanks alot.
Mileage to a battery is useless, Try to jump start it with another car and then take it out for a drive to charge it up. after 30 mins it should be ok. If not then you need a battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Mileage to a battery is useless, Try to jump start it with another car and then take it out for a drive to charge it up. after 30 mins it should be ok. If not then you need a battery.</TD></TR></TABLE>
True, my R's battery die at 30k, I replaced it. running good.
you get get it charged. Cause it might be that you forgot to turn the headlights off or something.
Have you jump started it yet? Seriously, maybe you left an interior light or trunk light on.
Also, could be the alternator. I wouldn't buy a battery unless I was sure it was the battery.
If you do get one:
http://www.surplusev.com/
G13EP Battery with Automotive Terminals $60.00 ea
11.5 lbs (about the size of 3 coke cans)
-Chris
If you do get one:
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R »</TD></TR><TR><TD CLASS="quote">update...jump started the car..
let it run for a bit
now im just gonna wait till morning...
if it works then
if it doesnt...
new battery
Are you there yet?
-Chris
if it works then
if it doesnt...
new battery
</TD></TR></TABLE>Are you there yet?
-Chris
I have the sears battery and it has been working fine and I give it a work out when I turn up the tunes
900wts
take a look, many options in this link: https://honda-tech.com/zerothread?id=685094
900wts
MooreBoost
Aug 31, 2005 08:53 PM
vizsual00
Aug 11, 2003 11:48 AM
