SHAKEY STEERING WHEEL?
Old Nov 27, 2004 | 12:09 PM
swiftstyles's Avatar
Default SHAKEY STEERING WHEEL?
sup, my steering wheel shakes constantly. The thing is it shakes from 1-120mph no matter what speed. Its a constant shake, it doesnt vibrate any faster on acceleration or deceleration? It shoke before and after I had new axles put in and new wheels and tires that have been balanced. I did try search!
Old Nov 27, 2004 | 01:02 PM
eda6's Avatar
Default Re: SHAKEY STEERING WHEEL? (swiftstyles)
I'm having the same problem myself. I planned on checking my ball joints and tie rods.
Old Nov 27, 2004 | 01:09 PM
Default Re: SHAKEY STEERING WHEEL? (eda6)
is that what happens when you have a bad ball joint cuz I have to admit my ball joints are riped.
Old Nov 27, 2004 | 01:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swiftstyles &raquo;</TD></TR><TR><TD CLASS="quote">sup, my steering wheel shakes constantly. The thing is it shakes from 1-120mph no matter what speed. Its a constant shake, it doesnt vibrate any faster on acceleration or deceleration? It shoke before and after I had new axles put in and new wheels and tires that have been balanced. I did try search!</TD></TR></TABLE>
Have you tried rotating the tires?
Old Nov 27, 2004 | 01:28 PM
hondaguyef's Avatar
Default Re: SHAKEY STEERING WHEEL? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Have you tried rotating the tires?</TD></TR></TABLE>
I am having the exact same problem. I am inversting in some competition engineering tie rods (Overkill) and I need to also replace my upper CA ball joints. I can't firgure out where the vibration is coming from but, I am prepping the car for next race season so if the shaking steering wheel goes away so be it.
Phil
Old Nov 27, 2004 | 01:33 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swiftstyles &raquo;</TD></TR><TR><TD CLASS="quote">is that what happens when you have a bad ball joint cuz I have to admit my ball joints are riped.</TD></TR></TABLE>]
It's just a possibility. Once the grease is gone it will accelerate wear on the ball joint. Metal to metal contact will eat the metal resulting in vibration. To see if the ball joint is bad jack up the front of the car and grab your tire. Put some force into it and push and pull the tire it should not move. To check the tie rod end remove the tire and try to move the tie rods. Both joints should not budge.
If the ball joints and tie rods are good get the tires rebalanced. Sometimes it takes three or four visits to get the tires balanced properly.
Old Nov 27, 2004 | 01:46 PM
sweet, gonna try out your techniques. Thanks for everybody's help. I know after I fix this problem something else will pop up then I will post again.
Old Nov 27, 2004 | 02:21 PM
drdisco69's Avatar
Shifted belts can make tires balance and still shake like crazy, ask me how I know..
Old Nov 27, 2004 | 02:22 PM
eda6's Avatar
Default Re: SHAKEY STEERING WHEEL? (drdisco69)
how do you know? lol
Old Nov 27, 2004 | 02:30 PM
msmotorsports's Avatar
Are your alignments straight?
Old Nov 27, 2004 | 02:38 PM
drdisco69's Avatar
Default Re: SHAKEY STEERING WHEEL? (msmotorsports)
Well, my steering wheel was shaking, so I rotated and balanced my tires. 80mph gives a great butt massage, and I'm thinking, wtf, I know I didn't balance my ******* tires wrong. I check them again, they're fine. I use the road force balance, and one of the tires has a 25lb oops in it. Might have something to do with the GIGANTIC pothole that found me...
If you can get them road force tested, it's worth a shot. Or rotate and see if things change.
SPOOLINmatt
May 29, 2008 11:16 PM
fbankins
Suspension & Brakes
Aug 8, 2006 07:03 PM
cbmprelude
Sep 9, 2005 08:13 PM
rtiadnoh
15
Feb 25, 2004 12:58 PM
trooper0641
18
Dec 25, 2003 05:26 PM
