Whats the difference between VTEC and VTEC-E?
Old Nov 25, 2004 | 04:30 PM
iphatcrxi's Avatar
Default Whats the difference between VTEC and VTEC-E?
Are the solenoids the same?
Old Nov 25, 2004 | 04:33 PM
eumoria's Avatar
Default Re: Whats the difference between VTEC and VTEC-E? (iphatcrxi)
http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
VTEC was originally designed to get more power out of the car by actively changing the timing and lift during operation. Honda is against boosting their engines so this is their "boost alternative."
VTEC-E is a variation of that in order to improve fuel economy. It's not necessarily the opposite of VTEC... but it can be considered so.
No they're not the same.
Old Nov 25, 2004 | 04:36 PM
iphatcrxi's Avatar
Default Re: Whats the difference between VTEC and VTEC-E? (eumoria)
What is the difference, they look almost identical
Old Nov 25, 2004 | 04:39 PM
eumoria's Avatar
quote from the link since you didn't bother to read it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by link-above &raquo;</TD></TR><TR><TD CLASS="quote">"VTEC works as the two cam/rocker pairs operates independently of each other. One of the two cam-lobes are intentionally drawn to be different. The one on the left has a "wilder" profile, it will open its valve earlier, open it more, and close it later, compared to the one on the right. Under normal operation, each pair of cam-lobe/rocker-arm assembly will work independently of each other."</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by link-above &raquo;</TD></TR><TR><TD CLASS="quote">"VTEC-E works by deactivating one intake valve."</TD></TR></TABLE>
Basically DOHC/SOHC "performance" VTEC runs always at 16valves, but opens up further during high RPM operation. The SOHC VTEC only operates on the intake valves, while DOHC VTEC uses both intake and exhaust operation. It just changes the opening, and duration of operation. VTEC-E runs in 12valve, the opens up to 16valve during high RPM. It basically uses 1 intake valve per cylinder during normal usage, then opens up both intake valves when you floor it up over whatever RPM it's set to. Very different, yet similar in nature. Read that site.
Modified by eumoria at 8:50 PM 11/25/2004
Old Nov 25, 2004 | 04:51 PM
iphatcrxi's Avatar
im talking about the solenoid
Old Nov 25, 2004 | 04:54 PM
iphatcrxi's Avatar
some guy has a SOHC vtec-e solenoid from a vx for sale and i wanted to use it on my sohc vtec zc
Old Nov 25, 2004 | 05:02 PM
iphatcrxi's Avatar
anyone know?
Old Nov 25, 2004 | 05:28 PM
iphatcrxi's Avatar
bump
Old Nov 25, 2004 | 05:45 PM
90LSpimpin's Avatar
You might have better luck postin this in the Tech or EG+ forum. Just a thought.
kbsoldier
70
Jul 5, 2007 04:11 AM
deadline
11
Jun 22, 2007 08:44 PM
tvman
Oct 31, 2005 07:08 PM
escape2me
Dec 25, 2004 11:51 PM
iphatcrxi
Nov 25, 2004 08:32 PM
