Help with tuning 18psi on C-16
Old Nov 22, 2004 | 04:02 AM
Importracer_001's Avatar
Default Help with tuning 18psi on C-16
I want to tune my B16A T3/T4 54 trim .63ar turbo on C-16 so I can boost 18 psi when I'm on the track
I've got 550cc injectors and I use Crome w/3bar mapsensor and I have a wideband and a EGT guage
My question is how should I tune the ignition tables?
How much should the max ignition timing be when I'm boosting 18 psi?
Thanks.
Old Nov 22, 2004 | 04:25 AM
TurboBumblBee's Avatar
Default Re: Help with tuning 18psi on C-16 (Importracer_001)
im tuned to 19psi on pump gas and have no detination problems at all.. as for how it was tuned i didnt tune it, it was tuned on a dyno at a shop
Old Nov 22, 2004 | 04:34 AM
seen4ever's Avatar
Default Re: Help with tuning 18psi on C-16 (TurboBumblBee)
PSI is relative, depending on turbo size, but if its a t3/t4e, 19psi can be almost pushing it.
Old Nov 22, 2004 | 06:14 AM
Default Re: Help with tuning 18psi on C-16 (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">PSI is relative, depending on turbo size, but if its a t3/t4e, 19psi can be almost pushing it.</TD></TR></TABLE>
yes i know that.. its a presicion sc44 t3/t4 turbo if i had of had the money fore more tuning i would have put in some c16 and saw that the turbo would ahve done after 20psi because of the efficiency of the turbo.. i will go back soon and hopefully hit the 500hp mark on race gas..
Old Nov 22, 2004 | 06:21 AM
turboEGhatch's Avatar
I would run race gas at that level, but C16 is overkill for only 19 psi.
Boyle.R
Oct 17, 2012 04:51 AM
TurboB16A300Hpteg
Dec 24, 2007 04:15 AM
jdmturbo1127
Apr 5, 2007 09:16 PM
b18c1wes
May 15, 2005 01:59 PM
MIKES
Nov 18, 2003 06:40 AM
