magical coolant
Old Dec 28, 2001 | 12:41 PM
SiTEC's Avatar
Default magical coolant
93 EG coolant keeps disappearing, flushed the radiator. it was fine for a while, now its gone again?? any advice
Old Dec 28, 2001 | 01:17 PM
DragII's Avatar
Default Re: magical coolant (SiTEC)
do you see any white smoke? or evidance of a leak? you are either burning it, boiling it, or leaking it.
Old Dec 28, 2001 | 02:15 PM
SiTEC's Avatar
Default Re: magical coolant (DragII)
no smoke, and no leaks. any tips?
Old Dec 28, 2001 | 04:36 PM
MGD's Avatar
MGD
check your oil (headgasket)
Old Dec 28, 2001 | 05:33 PM
deepnite's Avatar
sometimes there s just a very small leak..my son s accord kept loosing coolant and even the honda dealer couldnt find it..finally a rad. shop found it by preasure testing to hell..it was a pin size hole in the hose
Old Dec 28, 2001 | 07:21 PM
EH2DX's Avatar
check the bypass hoses, they hide leaks pretty good.
tooqwik1's Avatar
check the lower radiator hose it leaks on a lot of egs also check the water pump if its leakin replace asap
Old Dec 28, 2001 | 08:20 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Guaranteed cure !!!
93 EG coolant keeps disappearing... any advice???
Bar's Leaks Cooling System Sealer permanently seals leaks in plastic, aluminum, and metal radiators, heater cores, blocks, heads, gaskets, and freeze plugs. Prevents rust, cuts electrolysis, and lubes water pump. Compatible with all brands of antifreeze including extended life. Use one bottle for 4 cylinder engines and two bottles for 6 and 8 cylinder engines.
Bar's Leaks Cooling System Sealer (5.5 oz.) $2.99
Old Dec 28, 2001 | 08:23 PM
Kamin's Avatar
Default Re: Guaranteed cure !!! (BlackDeuceCoupe)
my 94 civic is doing the SAME DAMN THING
its leaking a full tank a collant a week yet there is no smoke no leak.
i just keep telling myself ill fix it after the swap.
Old Dec 28, 2001 | 08:31 PM
HT White Ops
Default Re: Guaranteed cure !!! (KAMiN)
my 94 civic is doing the SAME DAMN THING... i just keep telling myself ill fix it after the swap.
$2.99 + tax will "fix it!"
Old Dec 29, 2001 | 11:46 AM
SiTEC's Avatar
i can get that at pepboys ?
Old Dec 29, 2001 | 11:53 AM
HT White Ops
Default Re: Guaranteed cure !!! (SiTEC)
Yep, been around since the 40's. Everyone carries it. Most OEM's put it in at the factory. This **** is the bomb!
Old Dec 29, 2001 | 02:22 PM
94civicx's Avatar
New User
have the same problem in my 94 ex. I had a post about 1 month ago concerning it. never did figure it out, it stops sometimes but then other times I go through a reservoir of coolant every 3 days
Old Dec 29, 2001 | 08:15 PM
Kamin's Avatar
Default Re: Guaranteed cure !!! (94civicx)
mines about a week or so.
damn i hate that. ill get some this week pre-swap.
Old Dec 30, 2001 | 01:08 PM
SiTEC's Avatar
i went out to get bar's leaks and they were out of stock of that exact bottle you had posted. instead they had bar's leaks in a clear bottle in powder form, is this ok?
[Modified by SiTEC, 10:08 PM 12/30/2001]
Old Dec 30, 2001 | 01:55 PM
976's Avatar
976
New User
The bar leaks will clough a leak and other important engine parts!
Old Dec 30, 2001 | 03:19 PM
SiTEC's Avatar
Default Re: Guaranteed cure !!! (B21A)
would you have any other suggestions?
Old Dec 30, 2001 | 05:42 PM
HT White Ops
Yeah, that'll work too. Just go to a different store. If you go the powder route, try Solder Seal. It's the best powder.
Old Dec 30, 2001 | 05:43 PM
HT White Ops
Huh? What R U talking about??? Speak English, please...
SeanK325
Jun 22, 2010 02:52 PM
JDM_HAMSTER
Jun 26, 2008 01:55 AM
hookedonvtec
Oct 8, 2004 04:18 PM
vtecdc2
Nov 4, 2003 06:44 PM
redsled00
Jan 22, 2003 07:40 AM
