Couple questions before install *searched*
Old Nov 21, 2004 | 05:41 PM
4_door_teg's Avatar
Default Couple questions before install *searched*
Well I've got almost everything I need for my install, just waiting to get my wideband and wastegate flange/dumptube. I have a few quick questions that I've searched for and couldnt find the answer to.
1990 integra w/ b16
I have an hks wastegate and need to know if the vacuum line goes from the top nipple or the bottom one and what happens to the one that isn't used? just cap it off? I will be running the line to a nipple on my first charge pipe like 2 inches off the turbo.
Where do you guys buy your vacuum lines? I bought mine from canadian tire but I tihnk it won't work. I had a homemade catchcan hooked up with it and after a few weeks the line sucked shut (was to hot I'd imagine) and blew up my catchcan lol
How do you get jb weld of your hands
thanks guys
Old Nov 21, 2004 | 06:27 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: Couple questions before install *searched* (4_door_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4_door_teg &raquo;</TD></TR><TR><TD CLASS="quote">
thanks guys</TD></TR></TABLE>
********** constantly.
Old Nov 21, 2004 | 06:45 PM
Alchemist's Avatar
I bought my vac. lines from atp turbo and it cost me a grip. Then I found out that they sell the same stuff at autozone for way less. Hit up autozone.
Old Nov 21, 2004 | 06:48 PM
Si Shane's Avatar
Default Re: Couple questions before install *searched* (Alchemist)
you need to get lines made to handle oil, you cannot use vacum lines to carry oil.
Vacum lines are almost free, 10 dollars will get you probably around 15-20feet of it.
Old Nov 22, 2004 | 08:14 AM
Si Shane's Avatar
Default Re: Couple questions before install *searched* (Si Shane)
Go back and post on clubis, board *****!
Old Nov 22, 2004 | 02:47 PM
4_door_teg's Avatar
Thanks guys
"Go back and post on clubis, board *****!"
eh?
Old Nov 22, 2004 | 04:59 PM
4_door_teg's Avatar
I don't think he was tlaking to me now that I look at the times on hte other post
thanks for your advise
Smashback
Mar 12, 2013 02:31 PM
vestalfootball72
Dec 7, 2007 06:46 AM
yellow blur
Oct 7, 2004 06:22 AM
B18 CYA
Aug 5, 2004 10:01 PM
