I NEED SOME ADVICE
yeah, I got my car back from a shop the other dya and the dumbasses didn't tighten the alternator belt enough. I was wondering if anyone could tell me how to tighten an alternator belt down on a b16 and how much to torque it?
Modified by popinachubby at 12:29 PM 11/21/2004
loosen the bolts that would hold the alternator theres 2 on my d16 not sure on b16 then use your hand or a bar and push the alternator so there is tension on the belt but not too much you should be able to push the belt down about 1/2 inch when its tight then tighten the bolts and re check the belt tension.
read the first post what he says is correct.
https://honda-tech.com/zerothread?id=941341
oh yea in the future search
from what i can tell your not very mechanicly inclined. just take a good long look at your alternator from the top and jack it up and look at it from under neath if you cant figure it out get a helm manual or something. there shouldnt be any wires you should touch just 2 bolts. once you loosen the right 2 bolts you should get it.
if the belt is not tight enough it will squeal usually to let you know.
Loosen the top and bottom bolt slightly and the adjustment nut. Then take a long screw driver and pry the alternator away from you towards the firewall and tighten down the bolts.
Hill4589
Nov 14, 2008 12:26 PM
519[H]Si
May 25, 2004 09:25 PM
