I NEED SOME ADVICE
Alternator Help
yeah, I got my car back from a shop the other dya and the dumbasses didn't tighten the alternator belt enough. I was wondering if anyone could tell me how to tighten an alternator belt down on a b16 and how much to torque it?
Modified by popinachubby at 12:29 PM 11/21/2004
Re: I NEED SOME ADVICE (popinachubby)
loosen the bolts that would hold the alternator theres 2 on my d16 not sure on b16 then use your hand or a bar and push the alternator so there is tension on the belt but not too much you should be able to push the belt down about 1/2 inch when its tight then tighten the bolts and re check the belt tension.
Re: I NEED SOME ADVICE (slow94coupe)
alright, I'll work on it... if you're going to be online for a while I'd apreciate it if you could stay online just in case I need soemthing
read the first post what he says is correct.
https://honda-tech.com/zerothread?id=941341
oh yea in the future search
from what i can tell your not very mechanicly inclined. just take a good long look at your alternator from the top and jack it up and look at it from under neath if you cant figure it out get a helm manual or something. there shouldnt be any wires you should touch just 2 bolts. once you loosen the right 2 bolts you should get it.
Re: (EGmikeH22)
if the belt is not tight enough it will squeal usually to let you know.
Loosen the top and bottom bolt slightly and the adjustment nut. Then take a long screw driver and pry the alternator away from you towards the firewall and tighten down the bolts.
Hill4589
11-14-2008 12:26 PM
519[H]Si
05-25-2004 09:25 PM
