Cost to prepare honda blocks for big boost
Old Nov 19, 2004 | 11:29 AM
tech1145's Avatar
Default Cost to prepare honda blocks for big boost
I've been into Hondas for a long time. I've also been into boost for a long time. The project I want to start is a turbo LS/VTEC, but the lingering costs of sleeving the block and preparing the car to handle the wheelspin of the FWD configuration are the only things standing in my way. My question is, what is an average cost of preparing Honda blocks for decent amounts of boost and what is all involved besides boring/sleeving the block to actually making the car put the power to the ground? Lets say for example I was trying to make around 400 whp.
Old Nov 19, 2004 | 11:36 AM
boosted92's Avatar
Default Re: Cost to prepare honda blocks for big boost (tech1145)
You really don't need sleeves for only 400 WHP, but it's not going to hurt to sleeve your motor. Earl sells COMPLETE built shortblocks including Benson sleeves, CP pistons, eagle rods, ACL bearings, pretty much everything in your motor. His last sale price was 2975 (Or 3350 with Pauter rods) but I'm not sure what it would be now. Either way, 3 to 4 thousand is a reasonable price to pay for an assembled shortblock.
Old Nov 19, 2004 | 11:45 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Cost to prepare honda blocks for big boost (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote"> Earl sells COMPLETE built shortblocks including Benson sleeves, CP pistons, eagle rods, ACL bearings, pretty much everything in your motor. His last sale price was 2975 (Or 3350 with Pauter rods) but I'm not sure what it would be now.</TD></TR></TABLE>
GREAT info.! I will definitely look into this in the future.
Old Nov 19, 2004 | 11:58 AM
00s2KkId's Avatar
i pmed with Earl yesterday and it was i think 3350 for whole shortblock that is built to the hilt.. you have to supply the block and crank. not a bad price considering you will have a block that will hold massive boost if its tuned properly
Old Nov 19, 2004 | 12:09 PM
boosted92's Avatar
Default Re: (96GSRkId)
Also, look in the forced induction sponsors forum. Exospeed is selling sleeved blocks with Arias pistons and Eagle rods for 2595. While Benson has a great rep, so does Exospeed, so they are another option to look out for. Some people knock on Eagle rods, but I run them in both my motors (Including my GSR motor in my hatch which I shifted at 9800 and make over 500 WHP with) and I would have no qualms using them in ANY street car.
Old Nov 19, 2004 | 01:12 PM
eddyboy's Avatar
Default Re: (boosted92)
As for traction you can expect to pay the following prices depending on what brands you get. These are not hard numbers so don't take them as fact, just kind of a range of what u might have to pay. You can do all of them or just some but all will help with traction.
Good suspension 700-1300
Traction Bars 200-365
Gear/speed depenent boost controler 400-700
Motor inserts/mounts 36-400
LSD 400-900
GL with your build
Modified by eddyboy at 2:33 PM 11/19/2004
Old Nov 19, 2004 | 02:45 PM
tech1145's Avatar
Seriously? A stock B20 block can withstand 400whp?
Old Nov 19, 2004 | 02:48 PM
m R g S r's Avatar
I think mine was about $3500 so far, cp pistons, manley rods, benson sleeves, micropolished crank, balanced crank, all new seals, fluidamper harmonic balancer. .
Old Nov 19, 2004 | 03:04 PM
Ben Huynh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech1145 &raquo;</TD></TR><TR><TD CLASS="quote">Seriously? A stock B20 block can withstand 400whp?</TD></TR></TABLE>
Not exactly. With rods and pistons, the stock sleeves have held up to 400whp. This has worked for some and not for others.
Old Nov 19, 2004 | 05:01 PM
TurboJesse
Guest
Posts: n/a
Default Re: Cost to prepare honda blocks for big boost (ben@importparts.com)
81-81.5mm bore with stock sleeves with hold 500 easily with good tuning...i wouldn't push my luck with thinner b20 sleeves.
Old Nov 19, 2004 | 05:22 PM
kabaroo's Avatar
i wouldnt even try. like ^^ said, thinner sleeves. 400whp is about the limit for all b series motors with reliability kept in mind and the exceptions.
Old Nov 22, 2004 | 12:45 PM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote"> Exospeed is selling sleeved blocks with Arias pistons and Eagle rods for 2595.
Some people knock on Eagle rods, but I run them in both my motors (Including my GSR motor in my hatch which I shifted at 9800 and make over 500 WHP with) and I would have no qualms using them in ANY street car.</TD></TR></TABLE>
Thanks a bunch for the referral. We appreciate that very much.
our price of $2595 is so good for the parts that we use. OEM Bearings. obviously are more expensive than ACLs. and we use all OEM Honda parts for the main seal and bottom end gasket set.
As far as Eagle rods. We use them on race cars making over 500hp. No problem with them making 700hp on Irran Jolly's Exospeed built Hot Rod Car and also Eric Del Rosario/Goldmember's Exedy integra. Those are both Exospeed built race blocks. same blocks that any of you can get from us. There's nothing extra special on their blocks. Those cars can handle the HP and so will many of your street car setups as well.
SLPN H
Mar 2, 2009 07:47 AM
deathwingh22
Jan 27, 2008 02:21 PM
bboysake
Aug 11, 2006 03:02 PM
darkblue1998ls
Jan 19, 2006 07:42 PM
