my vtec wont kick in...:(
Old Nov 18, 2004 | 11:01 AM
hazeleyes76's Avatar
Default my vtec wont kick in...:(
hey- i got a new distributor..and ever since i got it..when i hit 5200..theres nothing.. i can tell theres a slight pickup..but no noise..its just silence. my vtec used to hit so hard; my car would jerk and all that fun stuff. lol.. but do u think i need to advance the timing?.. i advanced my old distributor..and then it went bad-and had to get it replaced...does it hurt my distributor when i advance it?
Old Nov 18, 2004 | 11:04 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: my vtec wont kick in...:( (hazeleyes76)
Check your oil level and do a search in archives under "VTEC".
Old Nov 18, 2004 | 11:05 AM
matix's Avatar
Does it hit the rev limiter at 6500. If it does you are in limp mode bc of something. I advance my timing to 18 degrees and run only 93 octane.It shouldnt hurt you distributor, but if you advance it too much it could hurt your motor. Hope this helps a little bit.
Old Nov 18, 2004 | 11:21 AM
97lude's Avatar
https://honda-tech.com/zerothread?id=830163
Old Nov 18, 2004 | 11:48 AM
Default Re: my vtec wont kick in...:( (97Lude)
thanks 97lude
Old Nov 18, 2004 | 12:41 PM
97lude's Avatar
no prob
Old Nov 18, 2004 | 02:15 PM
LudeyKrus's Avatar
Advancing the dizzy will not hurt the dizzy, but it may not be good for your motor if it causes it to detonate.
Old Nov 18, 2004 | 03:48 PM
CFLude97's Avatar
Default Re: (LudeyKrus)
quick question..really has nothing to do with the subject, and sry to hijack ur thread
hazeleyes, but do h22's have vtec in 1st gear? i have a 97 base and sometimes i think i have vtec in 1st and some times i dont..but all my other gears i know i do..just wanted to ask you guy sence you already talking about vtec cuting on.did not want to make another thread just to ask a simple question.
Old Nov 18, 2004 | 03:54 PM
5hif7's Avatar
Default Re: (CFLude97)
yes there's VTEC in first. When you say "sometimes i have it and sometimes i don't" do u let your car come to proper running temps before taking it to VTEC or do you start it up and go straight to redline?
Old Nov 18, 2004 | 04:36 PM
94Vtecluder's Avatar
Default Re: (5hif7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5hif7 &raquo;</TD></TR><TR><TD CLASS="quote">yes there's VTEC in first. When you say "sometimes i have it and sometimes i don't" do u let your car come to proper running temps before taking it to VTEC or do you start it up and go straight to redline?</TD></TR></TABLE>
pfft d15 #1 stuNN4 g035 5tr41t t00 r3dl1n3 f00! H3 41n't n3v4 sc4r3d!(@!###
Old Nov 18, 2004 | 05:16 PM
* B A N N E D *
Default Re: (94Vtecluder)
When I still had the Prelude. VTEC was very weird, some days it would come on strong, some days weak. Some days it would kick in, some days it won't after each gear.
That's why I went turbo, it kicks in all teh time, and I feel it all the time.
Turbo &gt; Vtec
Old Nov 18, 2004 | 05:21 PM
97lude's Avatar
Default Re: (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">When I still had the Prelude. VTEC was very weird, some days it would come on strong, some days weak. Some days it would kick in, some days it won't after each gear.
Turbo &gt; Vtec
ehh.....me=jealous
Old Nov 18, 2004 | 05:44 PM
mgags7's Avatar
vtec &gt; turbo
first off...read above....secondly....read above, turbo takes time to kick in, all i gotta do is hit 5200 and there i go, and i dont lose vtec when i shift gears, i took out the vtec blow off valve....hehe....
j/k....i like them both, and possibly a combination of the two.....
but.....
ALL MOTOR!!!!
one thing also, limp mode is not what your ecu is in if you can reach 5200 rpm, limp mode is: my car sounds like a chevy v8 and wont go above 3200 rpm.....your problem is no vtec mode, honda limits the motor at 6500 if theres no vtec b/c the engine would go very very rich up there running on the small lobes, so your in "limp vtec mode" i guess.....that doesnt rly matter but i figured i would add it......
check your spark timing and set it to 18, you dont need any more advance to get a good vtec kick....
p.s the ecu has no idea what gear you are in, so vtec will engage in every gear if its currently working.....
Old Nov 18, 2004 | 05:46 PM
97lude's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">vtec &gt; turbo
first off...read above....secondly....read above, turbo takes time to kick in, all i gotta do is hit 5200 and there i go, and i dont lose vtec when i shift gears, i took out the vtec blow off valve....hehe....</TD></TR></TABLE>
hmmm
Old Nov 19, 2004 | 01:41 PM
thank you for explaining that to me. i was so confused about "limp mode" everyone kept telling me i was in limp mode..but i didnt know what they meant. theres no CEL, soo i really dont know what the hell is wrong with my car..but im sad and i miss vtec lol
Old Nov 19, 2004 | 03:38 PM
quazar's Avatar
so 5200 when vtec is supposed to kick in on all Hondas?
Old Nov 19, 2004 | 03:59 PM
homesauce's Avatar
Default Re: my vtec wont kick in...:( (quazar)
no different hondas have different vtec engagement
Old Nov 19, 2004 | 05:00 PM
quazar's Avatar
Default Re: my vtec wont kick in...:( (homesauce)
so what about the 02 civic?
Old Nov 19, 2004 | 05:46 PM
im not sure for an 02 civic..but you can feel when it does..theres a change in the tone in your motor, and youll feel a pickup.. its prob around 4600-5200ish. not sure..try searchin it on google. youll feel it when it engages.
Old Nov 19, 2004 | 08:55 PM
Tonydalude's Avatar
6000k rpms
Old Nov 19, 2004 | 08:56 PM
Tonydalude's Avatar
Default Re: my vtec wont kick in...:( (Tonydalude)
I have limp mode sometimes to.. Usually im low on oil and my timing is a little advanced. That stuff about it being ok for your distributor... Uh yea i usually get about 2-3 a year. No biggie tho ha
Old Nov 20, 2004 | 11:59 AM
matix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonydalude &raquo;</TD></TR><TR><TD CLASS="quote">I have limp mode sometimes to.. Usually im low on oil and my timing is a little advanced. That stuff about it being ok for your distributor... Uh yea i usually get about 2-3 a year. No biggie tho ha</TD></TR></TABLE>
2-3 distributors a year wow. Somethings wrong with your car or something ive had mine advanced at 18 degrees for a year with no problems at all.
highwhey
Dec 29, 2010 10:06 AM
cloudconnected85
Oct 4, 2008 07:32 PM
Reddog
Aug 16, 2004 02:11 PM
gvillehnut
Feb 4, 2003 08:14 AM
GreenGSR
Jul 28, 2002 07:12 PM
