Need Help on mini-me please help please!!!!
Old Nov 13, 2004 | 08:37 AM
Skank_aSS_Dara's Avatar
Default Need Help on mini-me please help please!!!!
fixed the problem was the dizzy timing thanks guys
Modified by DaRa_Da_SkAnK at 6:58 PM 11/15/2004
Old Nov 13, 2004 | 09:14 AM
b18cx's Avatar
Default Re: Need Help on mini-me please help please!!!! (DaRa_Da_SkAnK)
Double check your cam/crank timing. Sounds like the timing belt is off a tooth or so.
Old Nov 13, 2004 | 09:25 AM
mmuller's Avatar
Mad Scientist
Default Re: Need Help on mini-me please help please!!!! (b18cx)
yep that and check compression
Old Nov 14, 2004 | 04:42 PM
Newt Dog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">Double check your cam/crank timing. Sounds like the timing belt is off a tooth or so.</TD></TR></TABLE>
Also check ignition timing. If you did not modify the dizzy the ignition timing will be too retarded to start..
Bassy_budz
68
Dec 16, 2013 08:38 AM
2kdrift
Engine Management and Tuning
Aug 10, 2010 02:24 PM
northemt88
Mar 15, 2008 12:57 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
wpgcivic
Jan 16, 2005 06:15 PM
