NPT fitting in rear of block?
Old Dec 25, 2001 | 09:33 PM
HX_Guy's Avatar
Default NPT fitting in rear of block?
I know the stock oil sensor is a BSPT fitting, and that is what Ive been using for my oil pressure gauge, but the hole on the fitting is TINY...like 1/16"!
Im going VTEC and I want to use a 1/8" NPT fitting...should I just screw it in even though it doesnt fit as well? (real tight fittings and doesnt thread all the way) or should I retap the hole for NPT?
What do you guys do?
Old Dec 25, 2001 | 09:48 PM
RedlinedVTEC's Avatar
Default Re: NPT fitting in rear of block? (HX_Guy)
I'd leave the oil pessure port alone and just run a line from the oil pump using z10's kit or just run a line from the back of the block. Here's a link to my buddy Del's site: http://www.geocities.com/thelsvtec/sshowto.html, he used the back of the block method. HTH
Old Dec 26, 2001 | 12:41 AM
Mista Bone's Avatar
D Tranny Guru
1/8" BSPT adapter to 1/8" NPT, do it the cheap way and pray it never fails.
Old Dec 26, 2001 | 06:21 AM
HX_Guy's Avatar
Default Re: NPT fitting in rear of block? (Mista Bone)
Hmm, well I have the 1/8" BSPT to 1/8" NPT fitting already, but like I saoid the hole in the BSPT fitting part is like 1/16"! Its TINY! Would it be alright to drill it out bigger?
Old Dec 26, 2001 | 06:25 AM
Crazydave's Avatar
have you seen the whole inyour oil pressure sender???
It's tiny too.
I'm hooking mine up this week.
I'll let you know
1/8 bsp - 4an--pretty braided oil line----4an-1/8npt--sender
[Modified by Crazydave, 7:41 AM 12/26/2001]
Old Dec 26, 2001 | 06:30 AM
HX_Guy's Avatar
Default Re: NPT fitting in rear of block? (Crazydave)
Yes I know the hole is small also..but not nearly as small as the one in my fitting. Its definately not the same size as a true 1/8" NPT fitting.
1/8" NPT is close to a -4an line...
The hole in my BSPT fitting is more like a -2an
zbower7
May 14, 2004 01:42 PM
beemaz
Mar 8, 2004 06:24 PM
RenoRacing
Sep 2, 2003 05:36 AM
reignofchaos
Aug 3, 2003 10:24 PM
integranator
Apr 24, 2003 09:42 PM
