My dashboard lights take have a delay coming on, how do I fix this?
Old Nov 10, 2004 | 08:12 AM
Kg cm2's Avatar
Default My dashboard lights take have a delay coming on, how do I fix this?
So, here's the problem:
Recently, about the past 3 weeks or so as it's been colder, I've been noticing that when I turn on my headlights or parking lights, they turn on immediately, but my dashboard lights for the speedo and tachometer and such take some time to come on. It seems like it is anywhere from 2-10 seconds of a delay.
Is there a relay that needs replacing? Or something else? Any help would be greatly appreciated. By the way, this is on a 1992 Civic Hatchback VX. Thanks.
Old Nov 10, 2004 | 10:58 AM
Kg cm2's Avatar
Default Re: My dashboard lights take have a delay coming on, how do I fix this? (Kg cm2)
Anybody have this same problem?
Old Nov 10, 2004 | 11:10 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
wow, that is an odd one. are all the bulbs illuminated? you may want to double check the connections on the back of the guage cluster. good luck.
dantastic's Avatar
its probably a problem with your dimmer switch. i noticed that my dash light would flicker alot when the weather got colder. i just bypassed it
Old Nov 10, 2004 | 11:33 AM
Kg cm2's Avatar
Default Re: (dantastic)
Rodney- Yes, once it illuminates, all of the bulbs are illuminated fine. There are no missing spots, or any other notable flaws.
Dantastic- When you bypassed the dimmer, what exactly did you do?
Anybody else with a theory as to what us causing this?
Old Nov 10, 2004 | 03:18 PM
Rodney's Avatar
Default Re: (Kg cm2)
dantastic is on to something there. def check the dimmer thumbwheel
Old Nov 10, 2004 | 03:23 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kg cm2 &raquo;</TD></TR><TR><TD CLASS="quote">
There are 3 wires going into the switch:
1) Solid Black
2) Black With Red Stripe
3) I-foget-the-color
Dissconnect the dimmer switch, then jump wires #1 and #3 together with a piece of wire or a paper clip. Your cluster and dash light will be permenately at full brightness. I used a piece of wire and some electrical tape. My dimmer switch was completely dead so my dash lighting did not work at all.
Old Nov 10, 2004 | 07:21 PM
Kg cm2's Avatar
Dantastic- I will try that tomorrow. Thanks for the quick response.
kevonster
Jan 26, 2013 11:29 PM
Draiga1988
Jan 4, 2012 03:33 PM
vtec.dc2
Dec 4, 2005 01:44 PM
hurican
Jul 17, 2004 08:45 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
