Possible electical problem with interior lights
Old Dec 3, 2005 | 07:19 PM
vtec.dc2's Avatar
Default Possible electical problem with interior lights
i've had this happen couple times now, i turn on the lights, outside lights will work but inside lights won't come on, so i turn the switch on/off and it will work from there.. never had a problem like this other than the light on the roof would come on with 1-2 second delay
anybody else had this type of problem? i hope i could figure out what it could be before it gets worse..
Old Dec 4, 2005 | 01:09 PM
vtec.dc2's Avatar
Default Re: Possible electical problem with interior lights (vtec.dc2)
up
Old Dec 4, 2005 | 01:21 PM
uNF$@#!'s Avatar
clearly describe your problem or people who may be inclined to respond will just ignore you
Old Dec 4, 2005 | 01:29 PM
vtec.dc2's Avatar
Default Re: Possible electical problem with interior lights (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">clearly describe your problem or people who may be inclined to respond will just ignore you </TD></TR></TABLE>
basically my cluster lights don't come on right away... when i turn on the lights, everything comes on except cluster lights, outside lights come on, other interior lights like climate control come on but cluster doesn't work until i drive the car for a minute or 2...
Old Dec 4, 2005 | 01:32 PM
uNF$@#!'s Avatar
is this issue consistent? first thing i'd check for any loose grounds...you havent touched the internal electricals have you?
trace the wiring from the dash, to the fuse box. the wire harness that runs between the two is actually fairly short.
Old Dec 4, 2005 | 01:44 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">is this issue consistent? first thing i'd check for any loose grounds...you havent touched the internal electricals have you?
trace the wiring from the dash, to the fuse box. the wire harness that runs between the two is actually fairly short.</TD></TR></TABLE>
its been consistent lately. nothing changed on my car, this started to happen right after outside temperatures dropped by a lot. i guess i'll check for loose grounds
alfaaay
Nov 10, 2009 05:30 PM
Luke G.
Jan 2, 2009 03:49 PM
vladd
Jul 21, 2006 07:30 PM
[626]phixionEF91
20
Feb 8, 2003 03:03 PM
