LS/VTEC reversed to install on b18c block?
Old Nov 8, 2004 | 07:32 PM
b18blackek's Avatar
Default LS/VTEC reversed to install on b18c block?
Im about to buy a type R head thats allready been tapped and setup for LS/Vtec is it possible to reverse the setup so i can use the head on my GSR motor?
How would i do so?
Old Nov 8, 2004 | 07:49 PM
mmuller's Avatar
Mad Scientist
Default Re: LS/VTEC reversed to install on b18c block? (B18BlackEK)
well, if the oil passage has a plug on it, then just take it out.
if its welded, then either drill or run an external oil line like
Old Nov 8, 2004 | 08:08 PM
b18blackek's Avatar
Default Re: LS/VTEC reversed to install on b18c block? (mmuller)
what i meant was i want the type R head for my GSR block but how do i reverse the tap?
Old Nov 8, 2004 | 10:39 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18BlackEK &raquo;</TD></TR><TR><TD CLASS="quote">what i meant was i want the type R head for my GSR block but how do i reverse the tap?</TD></TR></TABLE>
reverse tap?
all you have to do is take out the plug out of the vtec feed oil gallery.
Old Nov 22, 2004 | 06:44 PM
Naterror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
reverse tap?
NO, I think what you're not getting is he's undoing the ls/vtec.
Yes you can, just take the tap out of the hole and put the plug back in. If it's welded then just cap it off. If the dowl pins are drilled then you'll need the ls/vtec pins and use the upside down.
Old Nov 22, 2004 | 07:24 PM
mmuller's Avatar
Mad Scientist
Default Re: LS/VTEC reversed to install on b18c block? (Naterror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naterror &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you can, just take the tap out of the hole and put the plug back in. If it's welded then just cap it off. If the dowl pins are drilled then you'll need the ls/vtec pins and use the upside down.</TD></TR></TABLE>
OK, i was talking about the stock vtec feed oil gallery wich you have to plug when doing ls/v .if you want to reverse take out the plug...
I think your mistaken thinking is the adapter that you put on the head to connect the oil line. you do have to plug that back.
MMMK?
1sikhatch
Aug 8, 2008 12:45 PM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
SLow-Side
Nov 21, 2004 03:14 PM
99B16Si
Nov 22, 2003 03:54 PM
drumking15
May 14, 2003 10:06 AM
