Need Help: Car won't start, everything is normal
Old Nov 7, 2004 | 06:40 PM
Cyphear's Avatar
Default Need Help: Car won't start, everything is normal
I'll try to make this short. I built a new motor, its getting good compression, im getting spark and fuel for sure. The new motor is a just another b18b, but its built up and bored to 84mm. It was running when I pulled the old motor, but i can't get the damn thing to fire. I'm not getting a CEL and everything appears to be good, i've spent 10 - 15 hours trying to figure it out with no luck. I tried playing with the fuel a lot with uberdata to make sure it wasn't running too rich or lean, but i couldn't get it. The cam timing is right, i tripple checked it. Spark is at 16* BTDC so thats good. Could the injectors be spraying at the wrong time? When i turn it over all i hear is the motor cranking and a little *blewp* sound that just sounds like normal compression.
any suggestions are appreciated. I'm going to put my stock injectors back in and un-chip my ecu next weekend, but i'm just trying that because nothing else is working.
Old Nov 8, 2004 | 04:21 AM
forcedspeed's Avatar
Default Re: Need Help: Car won't start, everything is normal (Cyphear)
sir have u chked your igniton coil, if it is good may be its the chip that has a problem
Old Nov 8, 2004 | 02:10 PM
IntegraGSR311's Avatar
Default Re: Need Help: Car won't start, everything is normal (forcedspeed)
ttt, this is my roomates car and i want to see it workin, plus then i dont have to drive him around anymore
Old Nov 14, 2004 | 02:14 AM
Cyphear's Avatar
bump. i tired unchipping the ECU and putting the stock injectors in and i tried another fuel pressure regulator, but it still isn't starting. any advice is appreciated!!!
Old Nov 14, 2004 | 12:24 PM
Cyphear's Avatar
bump.
Old Nov 15, 2004 | 05:02 PM
Cyphear's Avatar
still not starting. any ideas?
Old Nov 15, 2004 | 07:23 PM
TypeR0186's Avatar
Default Re: (Cyphear)
like wat forcedspeed said check your coil it might be bad.... plus can u read the timing mark when the car isn't running? coil can go bad after a compression test sometime. take out ONE of the spark plug with the wire attached, then crank the engine with the unpluged spark plug against any metal part of the engine. if there is spark then the coils are good. try that
Old Nov 15, 2004 | 07:30 PM
Cyphear's Avatar
Default Re: (TypeR0186)
I am getting a good spark when i turn the motor over with the plugs out (i haven't tried just one plug at a time, but i dont see why that would make a difference). I'm reading the timing while the motor is cranking. so the ignition seems to be all good...
Thanks for the reply
Old Nov 15, 2004 | 11:39 PM
Supahr_Ed's Avatar
put a stock ecu back in and start from there...
Old Nov 16, 2004 | 12:47 PM
Cyphear's Avatar
Default Re: (Supah_Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supah_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">put a stock ecu back in and start from there...</TD></TR></TABLE>
tried that.
Old Nov 16, 2004 | 03:56 PM
Honda Sport's Avatar
bump for you cause I'm in the same boat...
Old Nov 16, 2004 | 08:28 PM
Cyphear's Avatar
Default Re: (Honda Sport)
i got a few good ideas to try next time i get the chance:
- Check thermostat housing ground
- try spraying starter fluid in the cyilnders and unplugging injectors to get it to fire once
- check the rotor screw to make sure its on there good.
Old Nov 17, 2004 | 12:42 AM
Supahr_Ed's Avatar
try checkin your grounds...i had a problem like that once too, i still never found out what it was but i secured a wire that was exposed on my engine harness...it worked but my car still wouldnt keep idle till after a few tries...sorry wish i can help you more
Old Nov 21, 2004 | 05:25 PM
Cyphear's Avatar
a little update. I tried using starting fluid and I checked the thermostat housing ground and neither helped. I'm going to have a lot of time to mess with it in a few days so i'll keep you guys up-to-date. the grounds are all good...
Old Nov 21, 2004 | 05:47 PM
TypeR0186's Avatar
what the fuel pressure?
Old Nov 21, 2004 | 06:19 PM
Cyphear's Avatar
thats one thing i need to check. there is pressure for sure, and i tried swapping FPRs, but i haven't checked it with a gauge.
Old Nov 27, 2004 | 03:35 PM
Cyphear's Avatar
well, it took me long enough, but i figured it out! The part on the distributor thats only supposed to go in one way was in the other way. I was thinking the spark was on time because it was flashing at 16*BTDC but i wasn't thinking that it would show that if it was firing on the exhaust stroke. It runs amazing. Thanks for all your help.
JohnnyBuilt
Jul 23, 2011 05:19 AM
2kdrift
Oct 9, 2010 07:11 AM
b20c
Apr 14, 2010 09:08 AM
Na-Spirit
Jul 18, 2009 10:32 PM
alfee
Jan 29, 2006 04:38 PM
