havin trouble sohc vtec
i have a cx i put a vtec head on a crx si block when i had the non vtec head on there with the cx ecu .No codes,but i put a p28 ecu on there it throws a 41 (o2) i think its 4holds with a quick flash if you can help i would be thankful!!!
quick fix . the check engine light comes on without the car startin,this is the only code thrown an i put the cx ecu back on an theres no code?????
o its a single wire, whats up with info on your meet i can get some riders to come out we are in deltona
how to on the o2 would b helpful2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">did you change your 02 out to a 4 wire?</TD></TR></TABLE>Thats what im thinking
what do you mean by 4 wire theres only 1 were do the other 3 go in the ecu an were do i connect them to? give me a time an place on the meet .
Your code is for the heater circiut on the O2. You need to install a 4 wire O2 sensor and wire it to the ECU. Or use the original ECU with a RPM trigger box for the VTEC.
all you need to do is get a 4 wire o2, and kae sure you have the wireing for it. Then you are good to go. Where in orlando are you at? I can meet up and help you out if needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by localmotion »</TD></TR><TR><TD CLASS="quote">Your code is for the heater circiut on the O2. You need to install a 4 wire O2 sensor and wire it to the ECU. Or use the original ECU with a RPM trigger box for the VTEC.</TD></TR></TABLE>
The RPM selector is is not a good idea seeing that vtec is also activated via oil pressure and engine temp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">here ya go!
http://www.hybridautomotive.com/tech/o2/</TD></TR></TABLE>
Nice link
Nice link
thanx that sight helps , is it possible to slice into the single wire an run the second to the a6 slot? the other 2 wires dont seem 2 b needed on a 1 wire o2 ,would this work?
stay in touch i got at least 5 cars cominif the beotch will run haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by localmotion »</TD></TR><TR><TD CLASS="quote">oil pressure sensors disactivates vtec only if pressure drops.</TD></TR></TABLE>
Thats what i meant. but if you are forceing it to activate and oil pressure drops then your screwed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX »</TD></TR><TR><TD CLASS="quote">thanx that sight helps , is it possible to slice into the single wire an run the second to the a6 slot? the other 2 wires dont seem 2 b needed on a 1 wire o2 ,would this work?
stay in touch i got at least 5 cars cominif the beotch will run haha</TD></TR></TABLE>
i dnt think this would work. I would just get a p28 or a obd1 b16 ecu.
stay in touch i got at least 5 cars cominif the beotch will run haha</TD></TR></TABLE>i dnt think this would work. I would just get a p28 or a obd1 b16 ecu.
replace the o2 sensor with a 4 wire o2 from a obd1 civic, and just plug it into the harness, if u look in the harness it has the holes for the pins on the plug of the o2 sensor
vtec25
May 11, 2011 09:13 AM
Lamonte219
Nov 10, 2009 09:34 PM
BUDtoker
Nov 5, 2007 04:37 PM
