CHECK ENGINE LIGHT IS ON
Old Nov 5, 2004 | 03:54 PM
DOHC-ter AMIEL's Avatar
Default CHECK ENGINE LIGHT IS ON
i was driving and my chk engine lite went on. i did a visual check of all my wires, fluids and important stuff that might have gotten lose but everything is fine. i disconnected my battery for a while and still it came on then i took out the ECU fuse for a while and it still came on. any ideas or better yet. anybody have a trustworthy mechanic i can use or borrow to see whats wrong? in the west LA area near UCLA
Old Nov 5, 2004 | 04:02 PM
drdisco69's Avatar
Default Re: CHECK ENGINE LIGHT IS ON (AMIEL)
You need to pull the code to see what is wrong. For your 95 integra, there will be a jumper under the glove box with 2 wires. Short these wire together and turn the key on. The check engine light will flash, count the flashes.
Old Nov 5, 2004 | 04:07 PM
Default Re: CHECK ENGINE LIGHT IS ON (drdisco69)
wht do you mean "short these wire together"?
Old Nov 5, 2004 | 04:12 PM
drdisco69's Avatar
Connect them to each other.
Old Nov 5, 2004 | 04:34 PM
this is safe to do? i mean i dont wanna break it even more
Old Nov 5, 2004 | 04:52 PM
drdisco69's Avatar
Not only is it safe, it's the only way to read the codes. Thats the entire purpose of those wires.
Old Nov 5, 2004 | 05:18 PM
GeeReg's Avatar
https://honda-tech.com/zerothread?id=978933
i tried to check but i didnt see those wires. i guess its jst too dark. but just incase its located jusst behind the glove box?
Old Nov 5, 2004 | 11:54 PM
PrettyLude's Avatar
yes, two pin harness, you should be able to pull it out from underneath the glove box
Old Nov 8, 2004 | 04:58 AM
JimBlake's Avatar
Default Re: (PrettyLude)
More like alongside the glovebox. They're in the corner where the glovebox & the kickpanel come together. There's a green rubber holder with 2 blue plastic electrical plugs. One of the blue plugs has 2 wires, other has 3 wires. You want the one with 2 wires. Bend a paperclip & stick the ends into that plug to connect it's 2 wires together.
adambrasel
Oct 25, 2007 06:37 PM
TcUiRvBiOc
Aug 16, 2007 03:54 PM
decode22
Nov 5, 2005 10:04 PM
DOHC-ter AMIEL
Nov 5, 2004 04:27 PM
Simple
Nov 22, 2002 10:49 AM
