~~NEED HELP!!!~~
Old Nov 5, 2004 | 03:43 PM
DOHC-ter AMIEL's Avatar
Default ~~NEED HELP!!!~~
ny check engine light went on but i dont know whats wrong. i did a visual check and all the fluids and wires and stuff are still ok. i tried to dis connect my battery for 10 mins and even took out the ECU chip but the check engine light still came on.
Does anybody have or know a trustworthy mechanic i can maybe use or borrow in the west LA area?? shops are too expensive
Old Nov 5, 2004 | 03:50 PM
Default Re: ~~NEED HELP!!!~~ (AMIEL)
help pls..
Old Nov 5, 2004 | 04:03 PM
anybody?
Old Nov 5, 2004 | 04:07 PM
MaskedAP1's Avatar
just reset it.. there is a little bottom under the steeringwheel for reset it
Old Nov 5, 2004 | 04:08 PM
blacknbean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">just reset it.. there is a little bottom under the steeringwheel for reset it</TD></TR></TABLE>
the maitanence reqd light and CEL are different
find out what code you are throwing..u can figure out by going here http://www.c-speedracing.com/faq/03.php
Default Re: ~~NEED HELP!!!~~ (MaskedDC4)
that little reset button is for the maintenance required light. thats not on. the chk engine light is. thanks tho.
Old Nov 5, 2004 | 04:09 PM
MaskedAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMIEL &raquo;</TD></TR><TR><TD CLASS="quote">that little reset button is for the maintenance required light. thats not on. the chk engine light is. thanks tho. </TD></TR></TABLE>
my bad..for some reason, i thought its ur maintenance required light..
01DC-2's Avatar
https://honda-tech.com/zerothread?id=978933
sticky on the top. that says ECU AND ABS CODES HERE!
Old Nov 5, 2004 | 04:17 PM
dun trip thanks anyway tho bro
Old Nov 5, 2004 | 04:27 PM
thanks that will help a lot but itll have to wait till tomorrow morning when there is daylight. but does anybody have a mechanic?
B18CR-X
Mar 27, 2004 06:38 AM
theslugbug
Dec 19, 2003 03:33 AM
JumbosGS-R
Aug 5, 2003 05:04 AM
ITR 2K
Apr 11, 2002 08:05 PM
Eurasia00
19
Nov 23, 2001 05:40 PM
