Excedy clutch installed, now have problems
Old Nov 4, 2004 | 09:55 PM
89EF9's Avatar
Default Excedy clutch installed, now have problems
here's the scenerio. tonite i installed an excedy racing clutch and fidanza flywheel in a 99 Si. when i try to put it in 1st gear, it's like i have to force it in there, so i adust the pedal to see if the throw out bearing working correctly, and it is, so i set the pedal back where it should be.
has anyone had any problems with getting the shifter in the gears after a clutch install?
any help is appreciated.
Thanks
Jeremy
Old Nov 4, 2004 | 10:08 PM
SIRef9[831]'s Avatar
Default Re: Excedy clutch installed, now have problems (89EF9)
your going to have to get used to it a new clutch especially a perfromance one will be harder to shift because its catching. thats pretty much normal
Old Nov 5, 2004 | 06:41 AM
snatch's Avatar
Default Re: Excedy clutch installed, now have problems (SIRef9[831])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRef9[831 &raquo;</TD></TR><TR><TD CLASS="quote">]your going to have to get used to it a new clutch especially a perfromance one will be harder to shift because its catching. thats pretty much normal</TD></TR></TABLE>
I'm not sure I agree with that 100%. I NEVER had any problems with harder shifting after putting in a performance clutch. Check the clutch fluid and try bleeding the clutch lines.
Old Nov 5, 2004 | 10:54 AM
tgreaves's Avatar
Did you make sure the stepping on the flywheel was correct for the Exedy clutch your using..
Old Nov 5, 2004 | 01:51 PM
89EF9's Avatar
Default Re: Excedy clutch installed, now have problems (tgreaves W)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves W &raquo;</TD></TR><TR><TD CLASS="quote">Did you make sure the stepping on the flywheel was correct for the Exedy clutch your using..</TD></TR></TABLE>
what do you mean by stepping?
Old Nov 5, 2004 | 01:56 PM
tgreaves's Avatar
You need to grind the flywheel so that the base and the friction surface are a certant distance apart from each other..
Its call the flywheel stepping.. I know on my Exedy clutch it was .063 negative..
Old Nov 5, 2004 | 01:58 PM
drdisco69's Avatar
The height of the mating surface above the mounting hole surface, like this:
_______------------_________
Wouldn't Fidanza make the stepping the same as the stock flywheel for compatability? My friend has a Fidanza flywheel, and while it engages differently, it worky fine.
Damnit, again!
Old Nov 5, 2004 | 02:22 PM
msmotorsports's Avatar
Just make sure the lines are completely bled
Old Nov 5, 2004 | 02:52 PM
tgreaves's Avatar
Default Re: Excedy clutch installed, now have problems (drdisco69)
I had to have my stock flywheel ground to match what the Exedy flywheel needed..
Old Nov 5, 2004 | 02:58 PM
drdisco69's Avatar
You mean match the clutch?
Thats odd. Did you get something wild, or an off the shelf item?
Old Nov 5, 2004 | 03:05 PM
tgreaves's Avatar
Its an Exedy 3 puck race clutch.. I had to get the stock flywheel ground to the specs that Exedy said they had to be for that clutch..
Old Nov 5, 2004 | 03:17 PM
drdisco69's Avatar
I can maybe see it for a clutch like that, but even then, could they not have designed it for the stock flywheel dimensions? I think that for someone buying a mild exedy clutch as a little upgrade for a worn stock clutch, the suprise of having to machine the flywheel is kinda poor planning by exedy. My Clutchmasters stage 3 bolted on fine. Engages a little low, but I like it like that for faster double clutching.
Old Nov 5, 2004 | 03:23 PM
tgreaves's Avatar
Every clutch has a stepping that it needs.. And you should always get your flywheel ground for a new clutch.. And getting the flywheel ground and stepped is like $30 at a machine shop..
Old Nov 5, 2004 | 04:52 PM
machine4321's Avatar
had the same problem with my exedy(modified by another company and renamed)
ever since i put it in first doenst go in 40%of the time ...also when i back up it wont go into first at all......its not disengauging properly and is draging ...the steppign thing is a dam good idea ..that could be a good fix for me ....good call
Old Nov 5, 2004 | 05:29 PM
tgreaves's Avatar
Default Re: (machine4321)
Yep.. I drag mine all the time and never had a problem with it..
Old Nov 5, 2004 | 08:45 PM
2k.civic.si's Avatar
Default Re: (tgreaves W)
hmmm....im running the exedy racing clutch with exedy 10lb flywheel and cant tell the difference except increased petal pressure
2fastGSR
Oct 1, 2010 07:39 PM
98R-1144
Jun 27, 2008 07:40 AM
tommyofyork
Feb 27, 2007 05:57 PM
cinq
Mar 26, 2004 11:30 AM
