larger valves or no?
Old Nov 4, 2004 | 02:21 PM
cxVtecC1's Avatar
Default larger valves or no?
I have a b18c1 head that is getting a pnp,i was planning on do a valve job,is there a better kind of valve job i understand about the the 3+5 angle vjobs,but is one better for a boosted application than the other ? also im buying parts now and thinking about valves would that be worth it or no,if anyone knowsgood machine work/hondata dealer/tuners in the north east let me know...facts only appreciated
Old Nov 4, 2004 | 02:46 PM
Fkned's Avatar
Default Re: larger valves or no? (cxVtecC1)
The valve job has to match the porting,so whoever is porting it will know what to use.
Old Nov 4, 2004 | 05:09 PM
cxVtecC1's Avatar
Default Re: larger valves or no? (Ed's Racing Heads)
would there be a more desired one to have (valve job)?and do people run over sized valves in boosted engines
Old Nov 4, 2004 | 05:12 PM
Fkned's Avatar
It all depends on the port work,I prefer to use .5mm on int and 1mm over for exhaust on turbo apps.I've used that set-up on 8 sec Hot Rod class cars and 6 sec pro rwd cars.
Old Nov 4, 2004 | 08:02 PM
cxVtecC1's Avatar
so the amount of "angles" is determined by how much porting is done to the head?correct?
Old Nov 4, 2004 | 08:24 PM
Fkned's Avatar
Each porter has a style of valve job and will vary from head to head.I personally like to do a 3 or 4 angle job for the intakes and a radius for the exhaust but some like to do radiused intakes as well.
Old Nov 5, 2004 | 03:57 AM
cxVtecC1's Avatar
do you have a website or conact i live in MA and was curious about your work email adress?
Old Nov 5, 2004 | 05:39 AM
Fkned's Avatar
sorry no web site,edsracingheads@msn.com,or 610-529-7028
Old Nov 5, 2004 | 05:51 AM
IN VTEC's Avatar
How much of the seating surface does a radiused valve retain? Is it still a 45 degree seat angle?
Old Nov 5, 2004 | 06:12 AM
Fkned's Avatar
Default Re: larger valves or no? (IN VTEC)
I'm not saying what angle I'd use but the seat will be 1mm -1.5mm wide.
Old Nov 5, 2004 | 06:18 AM
IN VTEC's Avatar
Right....can't give away all the mojo.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
kornerk12
11
Jul 3, 2009 03:55 AM
7rrivera7
Nov 7, 2005 03:11 PM
BeerMan
Jan 27, 2004 10:11 PM
Slick GS-R
Apr 3, 2002 01:57 PM
