gapping the rings tight or loose??
Old Nov 4, 2004 | 08:09 AM
dumpeDc2's Avatar
I'm a Jackass
Default gapping the rings tight or loose??
hey im gonna be putting my motor back together today it's a Lsvtec turbo with Je pistons and stock steves it is better to gap the rigs a little tighter or looser????
Modified by dumpeDc2 at 9:39 AM 11/4/2004
Old Nov 4, 2004 | 10:20 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: gapping the rings tight or loose?? (dumpeDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">hey im gonna be putting my motor back together today it's a Lsvtec turbo with Je pistons and stock steves it is better to gap the rigs a little tighter or looser????
Modified by dumpeDc2 at 9:39 AM 11/4/2004</TD></TR></TABLE>If they're a little loose the worst that will happen is a little more blowby. If they're too tight and you get ring bind, your engine is fubarred. Right on the money is best of course. You decide.
Old Nov 4, 2004 | 07:26 PM
Seth21's Avatar
I'm assuming you had the block honed right? Your gonna need to check the rings in each cylinder with a feeler gauge use .016 so if you put your ring in #1 cylinder and it reads .018 you'll need to get a ring grinder out and take .002 off of it to achive the .016 and you'll have to repeat this process in all 4 cylinders hope this helps
Old Nov 5, 2004 | 01:24 AM
Sack Master's Avatar
Default Re: gapping the rings tight or loose?? (550whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo &raquo;</TD></TR><TR><TD CLASS="quote">If they're a little loose the worst that will happen is a little more blowby. If they're too tight and you get ring bind, your engine is fubarred. Right on the money is best of course. You decide. </TD></TR></TABLE>
Old Nov 5, 2004 | 04:07 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 550whp &raquo;</TD></TR><TR><TD CLASS="quote">if you put your ring in #1 cylinder and it reads .018 you'll need to get a ring grinder out and take .002 off of it to achive the .016</TD></TR></TABLE>
Now I don't put many motors together, as the ones I deal with don't break very often. But it seems to me that if you have a larger gap than the spec, and you go grinding away, you're going to end up with an even larger gap. .018 + .002 = .020
Old Nov 5, 2004 | 06:17 AM
Fkned's Avatar
Since you don't know the right specs for the rings I'm going to go ahead and assume you also don't have or know how to use a ring grinder,correct?So take it to someone who does and you'll be ok.Rings are the sealing point of the engine if there wrong the motors useless.
Old Nov 6, 2004 | 03:30 PM
Denny Crane's Avatar
"...if you put your ring in #1 cylinder and it reads .018 you'll need to get a ring grinder out and take .002 off of it to achive the .016..."
Yikes! Are you sure this is how it's done?
Old Nov 6, 2004 | 03:55 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: gapping the rings tight or loose?? (hybrid2nr)
ok I just got a ring grinder so alls I need to do is gap them with a feeler gauge. but to find the gap for the JE rings they say take the boreX.005=the ring gap needed . So how do I fint the bore without a micrometer? it is a vergin 99ls block that I had bored 20 over what's the bore size?
Old Nov 6, 2004 | 04:52 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">ok I just got a ring grinder so alls I need to do is gap them with a feeler gauge. but to find the gap for the JE rings they say take the boreX.005=the ring gap needed . So how do I fint the bore without a micrometer? it is a vergin 99ls block that I had bored 20 over what's the bore size?</TD></TR></TABLE>
Don't take this the wrong way but do you know how to grind rings?It's not just put the ring in and grind away,yaknow.The ring needs to be square at the meeting ends and they need to be deburred corectly after grinding,have you seen it done before?Is that block bored .25 over in mm or .020 in standard?An ls bore is 81mm or 3.159.
Old Nov 7, 2004 | 09:10 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: gapping the rings tight or loose?? (Ed's Racing Heads)
no I have never grinded rings or event seen it done but I think I got a pritty good idea on how to do it. when I ordered the pistons I asked for 20over bore for a b16sence im useing a b16 head.but on the je spec. sheet it says bore 3.209 (81.51) it aslo said for a type R motor on the box but I dont know what that is for the part # is 188982.
Old Nov 7, 2004 | 10:06 AM
Fkned's Avatar
Ok i rechecked my math and it was off,a mm is about .039 so .020 over is right at .5mm so your ok.I hope your right w/the rings I'd hate to see you post later that you have low compression or have blowby into the crankcase.
5_Lug_B
Aug 5, 2007 09:26 PM
RACING INTEGRATION
Jun 26, 2005 09:34 AM
vtec.dc2
Sep 24, 2003 09:06 AM
crx1856
Sep 16, 2003 09:44 AM
crx1856
Sep 16, 2003 05:33 AM
