NEED HELP ASAP
Old Nov 2, 2004 | 06:07 AM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
Default NEED HELP ASAP
this morning out of nowhere my check engine light goes on. dropped my bro off and came home. waiting at the stop light my car starts to idle kinda hard (i dont know where its idling at because i have no tach). after idling hard it shuts off. first the battery light then the oil light. could it be my alternator kuz its been squealing a lot lately?
Old Nov 2, 2004 | 06:10 AM
DaKINE-Ek's Avatar
Default Re: NEED HELP ASAP (DaKINE-Ek)
i dont know if this helps but it is a 96 d16y7 wit 95,xxx on it, and it was cold this morning.
Old Nov 2, 2004 | 06:14 AM
DaKINE-Ek's Avatar
bump i need help
Ya@inlinePRO's Avatar
did you check what the CEL is throwing?
if your alternator has been squeeling or making noises you should fix it.
Old Nov 2, 2004 | 06:19 AM
DaKINE-Ek's Avatar
Default Re: NEED HELP ASAP (kwik2nec)
no i havent checked how do i do that?
Old Nov 2, 2004 | 06:23 AM
DaKINE-Ek's Avatar
bump i hope its ok for me to go to school and come back
Old Nov 2, 2004 | 06:27 AM
EX-T's Avatar
take your car to AutoZone and they will be able to hook up a diagnosis scanner up to it and tell you what code it threw.
Old Nov 2, 2004 | 06:30 AM
dcsportsciv's Avatar
right where your ecu is, which is on the passenger side panel right by the door on the floor board. you should have 2 harnesses one will have 3 or 4 inlets on it and one will have 2 if you take some wire or somthing that can ground, put both ends of wire or something into both inlets on the harness, then turn your key to the run possition and your check engine light will start flashing. it will flash slow a couple of times then fast a couple times. make sure to count the slow ones then fast ones and thats the code number.
here is the site to go to for codes let me know if you have any troubles
http://tech.hybridgarage.com/tech/codes.html
Old Nov 2, 2004 | 12:06 PM
DaKINE-Ek's Avatar
Default Re: NEED HELP ASAP (dcsportsciv)
i think it might be my idle kuz when im rolling slow and i hit the brake the car stalls
Old Nov 2, 2004 | 12:32 PM
DaKINE-Ek's Avatar
bump for this
Old Nov 2, 2004 | 12:45 PM
93CivicSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaKINE-Ek &raquo;</TD></TR><TR><TD CLASS="quote">i think it might be my idle kuz when im rolling slow and i hit the brake the car stalls</TD></TR></TABLE>
This is just for starters....
Weak or dead battery -
dying or dead alternator
check the fuse for your charging circuit under the hood
Check for potassium chloride buildup on your battery terminals.
Old Nov 2, 2004 | 02:21 PM
DaKINE-Ek's Avatar
Default Re: NEED HELP ASAP (93CivicSI)
would a weak or dying battery or alternator cause the check engine light to come on?
Old Nov 2, 2004 | 02:36 PM
Ricey McRicerton's Avatar
Possibly. Why not drive your car to Autozone? They can check your codes for you as well as test your battery and charging system.
If you have a multimeter (voltmeter) you can check your battery and charging system yourself. Turn the **** to Volts DC (V with a straight line, then a broken line about that) and put the red lead on the positive battery terminal, and the black lead on the negative battery terminal with the car turned off. It should read somewhere around 12V. Now turn the car on. It should go up to somewhere around 14V because your alternator will come on.
The ECU codes thread at the top of the forum will show you how to check codes.
blakh
11
May 5, 2007 01:39 PM
usdmEHboy
Feb 18, 2007 07:34 AM
alexb16hb
Nov 19, 2005 10:20 PM
JDM DERF
Jan 27, 2005 07:50 AM
