motor with bent rods, crank still good to use
Old Nov 1, 2004 | 10:26 AM
VRD^don's Avatar
Default motor with bent rods, crank still good to use
okay..just bought a b18b for cheap, cause it had a bent rod.going to rebuild it anyways...okay the guy told me that it had a bent rod..and i was like..no problems, going to rebuild anyways..i bought..brought it home..took the thing apart and now im just waiting on parts to arrive..i then talk to a local guy about it and dude say that a motor with a bent rod or spun a bearing the crank will be no good..but i look at the crank and it seems fine..so..will hte crank be useable in my build..thanks..
Old Nov 1, 2004 | 11:07 AM
VRD^don's Avatar
Default Re: motor with bent rods, crank still good to use (sohc_vtec)
ttt
Old Nov 1, 2004 | 01:33 PM
drdisco69's Avatar
If the crank is damaged, it might not be able to be repaired. The machine shop I dropped my block off at said they haven't had too much luck fixing honda cranks. Is the bearing journal damaged at all, or what? Did the rod bearing spin? If the bearings never touched, then the crank is fine. If the bearing spun, but the crank looks ok, have a machine shop check it out to make sure it's in round and all that fun stuff.
Old Nov 1, 2004 | 02:09 PM
VRD^don's Avatar
Default Re: motor with bent rods, crank still good to use (drdisco69)
i looked at it..crank seems fine...no scratches or anything. seems to be okay..
Old Nov 1, 2004 | 02:13 PM
atcrx's Avatar
Take it to a reputable machine shop.. let them check it for straightness.. Possibly could be warped... but unlikely.
Old Nov 1, 2004 | 02:14 PM
drdisco69's Avatar
If it's really not scratched, I'd run it. Make sure there's no little burrs or anything. Run your finger all around every journal.
Old Nov 1, 2004 | 03:39 PM
LoSt is BlaCk's Avatar
Default Re: motor with bent rods, crank still good to use (atcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atcrx &raquo;</TD></TR><TR><TD CLASS="quote">Take it to a reputable machine shop.. let them check it for straightness.. Possibly could be warped... but unlikely. </TD></TR></TABLE>
exactly. you won't know until they check it..if you decide to simply run it you might end up further in the hole money wise...
Old Nov 1, 2004 | 03:51 PM
drdisco69's Avatar
Default Re: motor with bent rods, crank still good to use (LoStMyBoOsT)
Thats why my ITR block is getting looked through and honed. Destroyed rod bearing on cylinder 1, crank looks fine, just a little burr. But the blowby on the piston made me want to make this motor brand new.
Old Nov 2, 2004 | 02:28 PM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOsT &raquo;</TD></TR><TR><TD CLASS="quote">
exactly. you won't know until they check it..if you decide to simply run it you might end up further in the hole money wise...</TD></TR></TABLE>
well..i just took a long look at it and there seems to be no scratches or deep gouges ..seems fine..might do ahead and use it..
s032105k
Dec 28, 2010 06:17 PM
DanishR
Oct 7, 2007 07:41 PM
takumi604
Mar 26, 2005 09:23 PM
92LudeSR
Jul 11, 2003 07:09 AM
S13 slide
Dec 2, 2002 05:54 PM
