will 35gph and 440s suffice?
Old Oct 31, 2004 | 08:39 AM
fastsohc's Avatar
Default will 35gph and 440s suffice?
Here is the setup.
f23a1 with 40 over pistons.
ported and polished head. decked 30
ss valves, crower regrind,maxbore 64mm tb
aem fuel rail, pressure regulator,v2 intake
dc header,
venom vcn2000 set at 100 shot,
hondata s200.
i talked to venom and they recommended 440s and a 35gph 80psi pump.
Old Oct 31, 2004 | 08:55 AM
PyroProblem's Avatar
Default Re: will 35gph and 440s suffice? (fastsohc)
That would probably work,Im assuming the 35gph is an inline pump?
Id just go with an in-tank walbro. And with the Hondata you can control any sized injectors so you could always go bigger if your not sure...RC engineering website has an injector calculator that will tell you what you need. Check them
Old Oct 31, 2004 | 08:57 AM
fastsohc's Avatar
Default Re: will 35gph and 440s suffice? (PyroProblem)
actually its an intank.Always heard that intank is better.
ELSpool
May 26, 2004 12:11 PM
hatchback
May 20, 2003 09:00 PM
g2turbo
Nov 30, 2002 05:03 PM
Precision DC4
Oct 25, 2002 09:18 AM
Mikex25
Oct 30, 2001 09:50 PM
