please help with turbo timer
ok i bought a greddy auto timer and i was wiring it up and one wire wires in with another wire that goes into the ecu its the speed sensor wire??? where is that? and 3 wires go into the ignition....one wire goes into another wire that has constant power..which one is that i got the helms on which wire is the acc wire and the on wire but which one has constant power?????help
well i got it wired up and it comes on and everything but when i shut the car off the timer counts down but the car shuts off?!?!?!?!?!?! HELP
i did that...it did the same thing except before the timer wouldnt come on when i turned it to acc.....when i switched the wires the timer comes on when the key is at acc
i didnt wire the speed sensor wire (the purple one) if that matters...when you turn the car off does the ebrake have to be up right??? i wired the brown wire in wtith the ebrake.....i dont think i did anything wrong....but il turn the car off....the motor will shut off but the timer will start counting down...
hey i just got done installing my turbo timer and it works and all but i couldnt turn my alarm on while the car is running. any1 with a alarm, can u turn the alarm on while the car is running? and which wire do u have to connect to the alarm?
90_EX_Civic
Mar 21, 2009 07:59 PM
T25 civic
Oct 6, 2002 02:11 PM
