compression test?
Can I compression test my motor with it out of the car? I have my b16 sitting in my garage and I'm wondering if it will read the max PSI by me turning over the crank with a ratchet?
yeah i got like 30psi across the board when i did this. and i only turned it over like once or twice. and i added a cap of oil to it and still got 30psi. think if i jump the started i will get a much higher reading? i sure hope so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx »</TD></TR><TR><TD CLASS="quote">anyone have any idea what results i should have gotten by cranking it by hand?</TD></TR></TABLE>
somewhere between 0 and maybe 60
the reading wont re right at all,
1. The enige isnt a vacume when its not cranking, Its not pulling in the sufficient amount of air.
2. Buy turning the crank by hand you are opening the valves longer so inconsistant amouts of air will enter..
you could do a leak down test, that would probally be the only thing you would be able to do while the motor is out.
DropSide
Apr 18, 2007 06:22 PM
civiclxb16a
Sep 7, 2006 06:54 PM
