Sleeving + Blockguard..??
Old Oct 29, 2004 | 05:05 AM
loud_whispers's Avatar
Default Sleeving + Blockguard..??
Im not sure if this has been covered before. If so, someone please link me..
In a nutshell, will sleeving your motor and adding a blockguard essentially make the motor more "bulletproof" in high boost applications?
Or will it be no use, and just be adding weight?
Or will it attribute to the demise of my motor? haha.
let me know.
thanks.
Old Oct 29, 2004 | 06:50 AM
PrettyLude's Avatar
it its a good design like benson's is, you don't need a blockguard
Old Oct 29, 2004 | 07:02 AM
Default Re: (PrettyLude)
that's not my question bro..
Old Oct 29, 2004 | 07:09 AM
mmuller's Avatar
Mad Scientist
a block guard wont fit anyways
Old Oct 29, 2004 | 07:28 AM
Mikey3000's Avatar
Default Re: Sleeving + Blockguard..?? (loud_whispers)
block guards are crap. if u sleeve your motor u dont need one.
Old Oct 29, 2004 | 10:17 AM
91civicDXdude's Avatar
blockguard is to sleeve as FMU is to standalone engine management system.
blockguard is to sleeve as "pulling out" is to sterilization.
a block guard is not needed on a sleeved block. A sleeved block does what a blockguard is intended to do, only it actually works.
Old Oct 29, 2004 | 11:31 AM
drdisco69's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">blockguard is to sleeve as "pulling out" is to sterilization.</TD></TR></TABLE>
LOL
Old Oct 29, 2004 | 12:58 PM
Kamin's Avatar
Default Re: (loud_whispers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loud_whispers &raquo;</TD></TR><TR><TD CLASS="quote">that's not my question bro..</TD></TR></TABLE>
you dont need to run both, a properly sleeved engine should NEVER have the sleeves fail.
Old Oct 30, 2004 | 11:48 AM
Default Re: (Kamin)
ok.
im getting mostly opinions here.
im in the tech forum looking for actual "tech" information.
my question is.
will a blockguard attribute additional "strength" to a sleeved block?
that's all i want to know.
im not looking for people to tell me that i don't NEED a blockguard with sleeves.
One guy said a blockguard will not fit with sleeves? Is this true also?
And a technical explanation as to why would be appreciated also.
let me know.
thanks.
Old Oct 30, 2004 | 01:16 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loud_whispers &raquo;</TD></TR><TR><TD CLASS="quote">ok.
a standard block guard will not fit if the new sleeves are thicker than the origionals.
im gonna repeat myself because you think its an opinion, there is NO REASON to run a blockguard with a sleeved engine. you are in for more headaches for NO added protection, infact you may encounter overheating problems because some block guards do produce issues like that on stock thin-wall sleeves, now you have a thicker wall AND something to block coolant flow to the most critical area of the sleeve, the point where combustion begins.
Old Oct 30, 2004 | 02:29 PM
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
im gonna repeat myself because you think its an opinion, there is NO REASON to run a blockguard with a sleeved engine. you are in for more headaches for NO added protection, infact you may encounter overheating problems because some block guards do produce issues like that on stock thin-wall sleeves, now you have a thicker wall AND something to block coolant flow to the most critical area of the sleeve, the point where combustion begins. </TD></TR></TABLE>
ok now that's an answer
Ok. so it will not fit with thicker, reinforced sleeves..
i was told that it would.
Please explain how it will not?
Old Oct 30, 2004 | 06:48 PM
mmuller's Avatar
Mad Scientist
if the sleeves are thicker, wich im ''pretty'' sure most if not all are; the blockguard wont fit in the water jacket.
thapimpfromchi
Dec 27, 2010 02:23 PM
ringminion_blank
Aug 3, 2008 03:28 PM
FOrSfEd
Feb 28, 2004 04:02 PM
vtecb20coupe
Jan 29, 2004 12:23 AM
torr
Mar 6, 2003 08:00 AM
