zex 59300 cam q's
Old Oct 29, 2004 | 11:47 PM
shrug's Avatar
Default zex 59300 cam q's
from what the zex website says, it seems the 59300 is compatible with the stock valvetrain. i know the 59100 is but from what i hear the 59300 requires valvesprings and retainers. since most street/strip and strip only cams require an upgrade, it only seems logical, could someone clear this up?
Old Oct 30, 2004 | 10:28 AM
91civicDXdude's Avatar
I have used the 59300 with stock valvetrain. So has my brother and a good friend. It will work with stock valve train, but i am poor and couldn't afford the upgrade, but i do recommend it. the cam can make useable power above the stock rev limit, and anytime you rev above the stock limit or have such a high lift as .455/.430, you should upgrade the valvetrain.
Old Oct 30, 2004 | 10:35 AM
shrug's Avatar
ah good stuff, i will upgrade the valvetrain eventually, i just wondered if i could use the cam for a while before i upgrade. also, do you NEED a cam gear? i could understand if i had the y8 cam so that i could adjust timing correctly, but people keep saying i need an adjustable cam gear. any truth to this?
Old Oct 30, 2004 | 05:32 PM
sk8rmike's Avatar
Default Re: (shrug)
i am using a stock cam gear on mine. it's just like a stock cam but it makes more power everywhere, especially in VTEC. i would highly recommend upgrading the valvetrain ahead of time so you do not bend a retainer.
Old Oct 30, 2004 | 08:05 PM
shrug's Avatar
ah good stuff thanks guys.
moonman
May 23, 2009 07:43 AM
sohctodohc
11
Jun 5, 2005 07:47 PM
hatchback19
Jan 23, 2005 05:11 PM
JdMCiviCCupE
21
May 21, 2003 05:26 AM
ImportHatch
26
Dec 4, 2002 05:23 PM
