Engine Swap Problems
Old Dec 20, 2001 | 09:38 AM
SiViK-R's Avatar
Default Engine Swap Problems
Sup honda techs, I just swapped a 98 honda civic ex automatic engine in my 96 dx hatchback and now when i crank it up it starts but it doesnt sound right...it goes vroom...vroom...vroom...until i turn it off(could i have plug the wires in wrong?)...hope yall understand what im trying to say...and when I step on the gas the engine dies out...all information given is appreciated...
Old Dec 20, 2001 | 10:18 AM
LshatchTurbo's Avatar
New User
Default Re: Engine Swap Problems (SiViKbOi)
when you mean vroom vroom, do you mean the idle is bouncing up and down. I would also definltly check if you put the plugs in there coresponding locations.
Old Dec 20, 2001 | 10:32 AM
Spade's Avatar
Did you swap an ECU in as well!?!? If not, you need a EX automatic ECU!!
Old Dec 20, 2001 | 10:39 AM
SiViK-R's Avatar
Default Re: Engine Swap Problems (Zynentech)
yes, thats whats im trying to say...what wires you think could of been misplaced?
Old Dec 20, 2001 | 10:41 AM
SiViK-R's Avatar
Default Re: Engine Swap Problems (Spade)
No i havent swap ECU but my mechanic said i could use the my original ECU...could this be whats causing the problem??
Old Dec 20, 2001 | 10:48 AM
Spade's Avatar
DUDE, the EX ECU controls VTEC the DX doesn't have it.......you need more wires with the D16Y8 as well. and a Vtec siloniod (sp?).
Old Dec 20, 2001 | 11:10 AM
SiViK-R's Avatar
So the wrong ECU is causeing my engine to rev up and down constantly?
Old Dec 20, 2001 | 11:12 AM
Spade's Avatar
That and lack of wiring for the VTEC control. Those are two issues.....it could also be a vaccum line.....but, my money is on the ECU since it was never ment to control a VTEC engine.
Crazydave's Avatar
It's something inside the throttle body..... I remember this happening to my friend in his civic..
I remember him taking off the TB and tightening some sensor or valve or something inside the TB
I don't remember exactly.. but I remember it was about the size of a quarter and it was round.
Sorry this was really vague
Old Dec 20, 2001 | 11:15 AM
Spade's Avatar
Default Re: Engine Swap Problems (Crazydave)
Are you talking about the Idle Air Control Valve that sits on the back of the Intake Manifold!?!
Old Dec 20, 2001 | 11:25 AM
New User
Did you plug in the right map sensor? That also causes messed up idles.
Old Dec 20, 2001 | 11:37 AM
Crazydave's Avatar
maybe.. I remember it was round...
I have to call him to be sure...
this was a long time ago...
too many years and too many beers
Old Dec 20, 2001 | 11:59 AM
SiViK-R's Avatar
let me tri swapping it around
Old Dec 20, 2001 | 12:28 PM
SiViK-R's Avatar
Okay its fixed now...the map sensors were on backwards...thanks for the help from all of you.
Old Dec 20, 2001 | 12:36 PM
Spade's Avatar
Sorry about the mis lead........how does it rev? Does it feel like it looses power in the higher RPM's?
Old Dec 20, 2001 | 08:48 PM
SiViK-R's Avatar
okay now the problem is that i loose power in high rpm...if i slowly accelerate ill make it to high speed, but if i put the metal to the floor fast the engine gets weak and wants to die out...what could be the problem now guys?
Old Dec 21, 2001 | 06:07 AM
Spade's Avatar
now it is the VTEC......it doesn't turn on and you feel you loose power at 3500-4000 RPM and up right!?!
Old Dec 21, 2001 | 08:28 AM
SiViK-R's Avatar
Yeah I lose power around 3500-4000 rpm...what should i get now?...another ECU?...if i need a different ECU...can i use any other ECU besides 98 EX Vtec ECU?
Old Dec 21, 2001 | 08:33 AM
Spade's Avatar
I am not sure with the D series but you can us any EX ecu and it should be fine.....
there is a much slower response here but.... http://pub34.ezboard.com/bhondadseries
Old Dec 21, 2001 | 08:43 AM
SiViK-R's Avatar
Okay thanks alot
Old Dec 21, 2001 | 05:18 PM
RedlinedVTEC's Avatar
You need the Ecu from a 96-98 Civic EX automatic.
Old Dec 21, 2001 | 05:28 PM
KS-R's Avatar
Default Re: Engine Swap Problems (RedlinedVTEC)
Ah.. .****.. and I just threw a auto Vtec ecu out.. That's what you needed too... Sorry.
Old Dec 21, 2001 | 06:43 PM
SiViK-R's Avatar
Default Re: Engine Swap Problems (KS-R)
Ah.............find it please!! I have a 98 manual ECU, but it wont work...anyone knows who has one for me???
Jsarv
Sep 24, 2012 08:37 PM
BigRonDawg
12
May 9, 2006 06:55 AM
cloven
Mar 15, 2006 09:00 PM
Quad-Damag
10
Jul 13, 2003 03:52 PM
dingusjt
May 6, 2003 09:56 AM
