400-450 WHP B16, what are the most common setups?
Hallo,
we plan a 400-450 WHP B16A Setup, what are the most common setups for this power?
what turbo is the best for this application?
how much bosst?
what compression?
how many octane?
what are the most problems i will get?
that the block must get sleeves, pistons and rods and so on is totaly clear... its just about the things around the engine.
Thanks for your help
Malte.
how much bosst?
what compression?
how many octane?
Malte.
here was our setup when we made 430 hp on my turbo 4 car back in the day
- 81.5mm je pistons, 9.0:1 compression
- eagle rods
- block guard
- stock head
- crower valve springs and retainers
- stock valves
- stock b16 cams
- edelbrock intake manifold
- holley 68mm throttle body
- 720cc injectors
- uberdata
- innovative gt61s turbo at 22 psi
430 at the wheels
- eagle rods
- block guard
- stock head
- stock valves
- stock b16 cams
- 720cc injectors
- uberdata
430 at the wheels
thats funny we have the same setup in our customers car but cp pistons 9.5:1 and jg springs and retainers we made the same hp
who says stock sleeves dont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch4Me »</TD></TR><TR><TD CLASS="quote">that all depends on how much boost, but I would at least run 93 octane for lower hp and boost</TD></TR></TABLE>
how much boost do we need aprox for 450 WHP??? i think someting about 20psi?!
Greets
Malte.
Greets
Malte.
Smarter than you
my buddy's B16 84mm w/ Precision gt35e makes 415whp @ 16psi. Im sure he will see this post later and give some more info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">my buddy's B16 84mm w/ Precision gt35e makes 415whp @ 16psi. Im sure he will see this post later and give some more info.</TD></TR></TABLE>
Go Brian!
Go Brian!
nice hp numbers, im planning on making in hte 400-450 range with
b16a 81.5mm cp 9.0:1
pauter rods
honda bearings
itr cams/ portflow springs
inline pro mani/innovative t3t4 57 trim .63 a/r
tial gate and bov 3" turbo back
Chrome p72
pauter rods
honda bearings
Chrome p72
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx »</TD></TR><TR><TD CLASS="quote">
Greets
Malte.</TD></TR></TABLE>
horsepower is not solely dependent on how much boost. you could make 350whp on a small t3 at 15psi, and 400 on 15psi from a t3/t4.
Greets
Hi Malte
Octane rating is not the same in the US and in Europe. I have been told that US octane 93 is around 98 in europe.
Yes i know, but i can recalculate it if someone tell me a number.
its also clear that 15psi on a T3 is not 15psi on a t4... this was the reason for my question about what type of turbo is the best and how much boost is aprox. needed for around 450 WHP.
Thanks
Malte.
Thanks
Malte.
- eagle rods
- block guard
- stock head
- stock valves
- stock b16 cams
- 720cc injectors
- uberdata
430 at the wheels
- eagle rods
- block guard
- stock head
- stock valves
- stock b16 cams
- 720cc injectors
- uberdata
430 at the wheels
91DA-C
Nov 7, 2010 05:20 PM
egb20boy1224
Jun 8, 2007 02:57 PM
