replaced engine no wont rev over 3 grand
Old Oct 24, 2004 | 10:25 AM
1SOL2NV's Avatar
Default replaced engine no wont rev over 3 grand
ok guys i swapped my D16Z6 and when i started it,the rpms were rough and i tried to give it gas it wont go over 3 grand and bogs down any suggestions
Old Oct 24, 2004 | 10:28 AM
Discosteak's Avatar
Default Re: replaced engine no wont rev over 3 grand (1SOL2NV)
incorrect firing order
Old Oct 24, 2004 | 10:29 AM
Discosteak's Avatar
Default Re: replaced engine no wont rev over 3 grand (BADEG6)
or incorrect tps setting
Old Oct 24, 2004 | 10:45 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
map/tps could be switch
Old Oct 24, 2004 | 11:08 AM
1SOL2NV's Avatar
it has a setting ?
Old Oct 24, 2004 | 11:09 AM
1SOL2NV's Avatar
how can i see if its the correct firing order
Old Oct 24, 2004 | 11:17 AM
SiLuck2's Avatar
Are you throwing any codes? 'Cause when I did my swap, I had Map/TPS sensors switched for the longest time.
Old Oct 24, 2004 | 11:20 AM
colombian linx's Avatar
check your cap and rotor same **** happened to me lol, are you throwing any codes?
Old Oct 24, 2004 | 11:35 AM
1SOL2NV's Avatar
Default Re: (colombian linx)
no its not throwing any codes
Old Oct 24, 2004 | 05:23 PM
Discosteak's Avatar
if you put a voltmeter on the tps it should be at like .42volts at closed position im not sure of the firng order but i will look it up for you
Old Oct 24, 2004 | 05:46 PM
1SOL2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 &raquo;</TD></TR><TR><TD CLASS="quote">if you put a voltmeter on the tps it should be at like .42volts at closed position im not sure of the firng order but i will look it up for you</TD></TR></TABLE>
do i put it on the wire?
Old Oct 25, 2004 | 12:30 PM
Discosteak's Avatar
on the tps
Old Oct 25, 2004 | 02:05 PM
1SOL2NV's Avatar
ok guys i replaced the tb gasket and its running good.I have another ? its smoking more than it should be what can i check for that?
Old Oct 25, 2004 | 02:09 PM
Archidictus's Avatar
Unceasing Measure
How bout your blood alcohol level? Jesus Christ, it's a D-series swap in a D-series chassis with all necessary D-series wiring. It's probably blowing moisture from sitting or oil from broken parts - of course we can't tell you which because you didn't detail the smoke.
[Jerry Meguiar]help me help you...HELP ME HELP YOU[/Jerry Meguiar]
Old Oct 25, 2004 | 02:36 PM
1SOL2NV's Avatar
Default Re: replaced engine no wont rev over 3 grand (Archidictus)
sorry its my first time and i can't afford to mess something up.....the smoke is white or light gray
radicaled434
Apr 28, 2012 11:34 AM
EnzoSpeed
Apr 8, 2006 07:53 AM
Crasian
25
Jul 28, 2005 02:10 PM
Pete_SI
Mar 22, 2005 03:12 AM
89 CRX SI
Apr 18, 2003 08:54 AM
