engine builders for LS...3 questions
im shooting for 200 to 250 hp range with my tdo5 turbo. i purchased a set of Eagle rods and CP pistons. i heard i dont need to gap the rings for my range of hp. is this true?
i need to purchase OEM rod bearings for my b18b LS motor but i only have honda dealers around here, is b20 CRV rod bearings the same?
i have read Boosted-hybrids site on engine building, is there other techniques u guys use to find rod bearing clearance? can i use my used rod bearings and plastiguage and find out from there?
Yes, you must always set your ring-end gap. Sometimes rings come close to the desired gap and sometimes they come with a .005 gap. A lot of it has to do with the manufacturer of the ring.
http://www.acuraautomotivepart...y.jsp <- you can find your parts here
You can use a dial bore and caliper to check clearances as well. Yes, you use your old rod bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">http://www.acuraautomotivepart...y.jsp <- you can find your parts here
it doesnt differenciate the color or the width of the rod bearings on that site...
OldSchoolSwap
Apr 22, 2011 03:59 AM
88Snatch
Dec 23, 2008 07:22 PM
