Engine bearings. opinions on Clevite 77 and ITM???
Old Jul 9, 2003 | 03:19 PM
Weston's Avatar
Default Engine bearings. opinions on Clevite 77 and ITM???
Anyone have experience and/or opinions on Clevite or ITM engine bearings? How about "top circle" piston rings? Thanks
Old Jul 9, 2003 | 03:40 PM
AzG35's Avatar
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (Weston)
I had Clevites in my motor before, they lasted well over 50,000 miles, raced for many of them too. They looked pretty good as far as wear. Probably could have gone a lot longer with them too. I haven't heard of ITM or Top Circle before. Depending on what you are doing, I would either go with ACL bearings, they are one size fits all and they work well. Clevites will work well too, but sometimes they need to be fitted to the motor. For rings, depending on the bore and the motor, I would use Honda or whatever manufacturer of pistons you use.
Old Jul 9, 2003 | 03:53 PM
reaction360's Avatar
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (AzSi22)
ACL
Old Jul 9, 2003 | 03:55 PM
ACL !
Old Jul 9, 2003 | 04:22 PM
Rocket's Avatar
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (reaction360)
I've seen one set of used Clevites for a Honda and it looked pretty good.
Their main bearings sometimes have the tang in the wrong place though.
ACL's are trouble free for the most part.
Old Jul 9, 2003 | 10:16 PM
civicsitek GanGsTa's Avatar
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (Rocket)
I've used ITM's in a few low budget rebuilds and they work fine. ACL is by far the one to get if you want the best non oem brgs.
Old Jul 9, 2003 | 10:20 PM
mmuller's Avatar
Mad Scientist
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (civicsitek)
I have ACLs, great piece on my eyes honda quality
Old Jul 9, 2003 | 10:25 PM
sporkcrx's Avatar
How could bearings be one size fit all?
Old Jul 9, 2003 | 10:35 PM
mmuller's Avatar
Mad Scientist
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (sporkcrx)
acls are green/brown, on my application they plastigauged perfect
Old Jul 10, 2003 | 12:52 AM
sporkcrx's Avatar
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (mmuller)
I bought a rebuild kit from importperformanceparts.net and the company is called top line. There's another member on here that rebuilt his engine with their kit and so far it's holding up fine for him. The kit is cheap so you might want to check that out as well. I didn't have to switch out any bearings, they all plastigauged perfect also
Old Jul 10, 2003 | 07:11 AM
Weston's Avatar
That's it... the rings were Top Line, not Top Circle.
Thanks for the replies. No one on the other boards seem to have a clue.
Old Jul 10, 2003 | 09:40 AM
slowdx's Avatar
ive heard of top line but nothing about there quality...i used acl bearings and honda rings in my rebuild
Old Jul 10, 2003 | 09:54 AM
Rocket's Avatar
Default Re: Engine bearings. opinions on Clevite 77 and ITM??? (slowdx)
Topline rings are good. Topline bearings are crap. I know I have a set on my bench.
Old Jul 11, 2003 | 02:55 AM
sporkcrx's Avatar
Woohoo! My engine is going to crap!
Old Jul 11, 2003 | 07:20 AM
dwn-shift's Avatar
ACL fit perfect, no clearance problems here..
revlimitcrx
Mar 3, 2007 05:00 PM
Revi
Sep 26, 2006 06:16 AM
boredracer408
Jan 3, 2004 08:20 PM
98civicEX
May 19, 2003 10:20 AM
InfamousRS
Feb 13, 2002 07:42 PM
