engine builders for LS...3 questions
Old Oct 23, 2004 | 08:07 AM
EKB18BPR3's Avatar
Default engine builders for LS...3 questions
im shooting for 200 to 250 hp range with my tdo5 turbo. i purchased a set of Eagle rods and CP pistons. i heard i dont need to gap the rings for my range of hp. is this true?
i need to purchase OEM rod bearings for my b18b LS motor but i only have honda dealers around here, is b20 CRV rod bearings the same?
i have read Boosted-hybrids site on engine building, is there other techniques u guys use to find rod bearing clearance? can i use my used rod bearings and plastiguage and find out from there?
Old Oct 23, 2004 | 08:11 AM
vaporboy12's Avatar
Default Re: engine builders for LS...3 questions (98B00STED)
any honda dealership and get your acura parts becuase both part come from the same factory. alwas gap you rings
Old Oct 23, 2004 | 08:30 AM
PrecisionH23a's Avatar
Yes, you must always set your ring-end gap. Sometimes rings come close to the desired gap and sometimes they come with a .005 gap. A lot of it has to do with the manufacturer of the ring.
http://www.acuraautomotivepart...y.jsp <- you can find your parts here
You can use a dial bore and caliper to check clearances as well. Yes, you use your old rod bearings.
Old Oct 23, 2004 | 04:15 PM
EKB18BPR3's Avatar
Default Re: engine builders for LS...3 questions (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">http://www.acuraautomotivepart...y.jsp &lt;- you can find your parts here
it doesnt differenciate the color or the width of the rod bearings on that site...
Old Oct 23, 2004 | 06:39 PM
fullracegsr's Avatar
ls bearings are the same as b16... the part numbers are exactly the same...
OldSchoolSwap
Apr 22, 2011 03:59 AM
88Snatch
Dec 23, 2008 07:22 PM
VTiSpec
Sep 12, 2005 02:04 PM
boredracer408
Jan 3, 2004 08:20 PM
Weston
Jul 11, 2003 07:20 AM
