WTF! My test pipe CEL just went away yesterday (I'm OBD-II).
Old Oct 22, 2004 | 06:14 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default WTF! My test pipe CEL just went away yesterday (I'm OBD-II).
So I went to start up my car yesterday, and when the key was on the On position, the CEL, SRS, oil, battery, all those lights came on as they do, but when I started the motor the CEL went away all of a sudden. It's been on for the last two months I've had the test pipe on solid.
Any ideas? Is everything okay then?
Old Oct 22, 2004 | 06:25 AM
GDM Z28's Avatar
Default Re: WTF! My test pipe CEL just went away yesterday (I'm OBD-II). (boostincoupe)
lol a car that fixed its self....i need to get me one of them bump for you! lol
Old Oct 22, 2004 | 06:43 AM
DC2R714's Avatar
Is the secondary o2 completely removed or just exposed outside?
When I had no cat and was OBDII all the secondary o2 needed to see was some air and it didnt throw a code. I had it ziptied under the car. That could be whats happening.
Old Oct 22, 2004 | 06:59 AM
RacerXI's Avatar
Default Re: WTF! My test pipe CEL just went away yesterday (DC2R714)
It'll be back.
Old Oct 22, 2004 | 07:36 AM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Is the secondary o2 completely removed or just exposed outside?
When I had no cat and was OBDII all the secondary o2 needed to see was some air and it didnt throw a code. I had it ziptied under the car. That could be whats happening.</TD></TR></TABLE>
I heard that wont work and it will still throw a code because the o2 has to see some dirty air not just fresh air. i heard it has to be between two different numbers....but im forgetting what numbers they were. BTW for the thread starter...is your o2 exposed? or in the exhaust flow?
Old Oct 22, 2004 | 08:25 AM
DC2R714's Avatar
Default Re: WTF! My test pipe CEL just went away yesterday (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">
I heard </TD></TR></TABLE>
Worked for me for over a year.
Old Oct 22, 2004 | 08:40 AM
PM-Performance's Avatar
it will come back . it resets it self after some time. Mine did that a few times when i was obd2
Old Oct 22, 2004 | 08:55 AM
GDM Z28's Avatar
Worked for me for over a year.</TD></TR></TABLE>
Well now im hearing it from you so who should i listen to? lol
Old Oct 22, 2004 | 09:17 AM
sci motorsports's Avatar
i've seen the cel bulb burn out before, this could be a possibility
Old Oct 22, 2004 | 11:56 AM
Rocks
Guest
Posts: n/a
Default Re: WTF! My test pipe CEL just went away yesterday (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">it will come back . it resets it self after some time. Mine did that a few times when i was obd2</TD></TR></TABLE>
after a certain time you turn the ignition the CEL goes off
Old Oct 22, 2004 | 12:16 PM
Bailhatch's Avatar
Default Re: WTF! My test pipe CEL just went away yesterday (Rocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks &raquo;</TD></TR><TR><TD CLASS="quote">
after a certain time you turn the ignition the CEL goes off</TD></TR></TABLE>
right on
Old Oct 22, 2004 | 12:24 PM
SOHC_MShue's Avatar
It will be back. Time for an obd1 conversion
Old Oct 22, 2004 | 02:46 PM
Default Re: WTF! My test pipe CEL just went away yesterday (SOHC_MShue)
Yes it's in the exhaust flow, and yes I'll be going Uberdata in the spring
Old Oct 22, 2004 | 05:18 PM
dsadas89das78934's Avatar
who's doin your ECU?
Old Oct 23, 2004 | 07:32 AM
Default Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">who's doin your ECU?</TD></TR></TABLE>
Not sure, probably a buddy of mine who chips ECUs all the time. Why?
kantfadedisazn
Aug 3, 2009 10:00 AM
01DC4
Honda S2000
Feb 27, 2008 12:57 PM
ActiveAero
Jun 16, 2002 06:24 PM
Qwikrex
Apr 11, 2002 05:17 PM
