WTF! My test pipe CEL just went away yesterday (I'm OBD-II).
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
So I went to start up my car yesterday, and when the key was on the On position, the CEL, SRS, oil, battery, all those lights came on as they do, but when I started the motor the CEL went away all of a sudden. It's been on for the last two months I've had the test pipe on solid.
Any ideas? Is everything okay then?
Re: WTF! My test pipe CEL just went away yesterday (I'm OBD-II). (boostincoupe)
lol a car that fixed its self....i need to get me one of them bump for you! lol
Is the secondary o2 completely removed or just exposed outside?
When I had no cat and was OBDII all the secondary o2 needed to see was some air and it didnt throw a code. I had it ziptied under the car. That could be whats happening.
Re: WTF! My test pipe CEL just went away yesterday (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 »</TD></TR><TR><TD CLASS="quote">Is the secondary o2 completely removed or just exposed outside?
When I had no cat and was OBDII all the secondary o2 needed to see was some air and it didnt throw a code. I had it ziptied under the car. That could be whats happening.</TD></TR></TABLE>
I heard that wont work and it will still throw a code because the o2 has to see some dirty air not just fresh air. i heard it has to be between two different numbers....but im forgetting what numbers they were. BTW for the thread starter...is your o2 exposed? or in the exhaust flow?
Re: WTF! My test pipe CEL just went away yesterday (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 »</TD></TR><TR><TD CLASS="quote">
I heard </TD></TR></TABLE>
Worked for me for over a year.
it will come back . it resets it self after some time. Mine did that a few times when i was obd2
Worked for me for over a year.</TD></TR></TABLE>
Well now im hearing it from you so who should i listen to? lol
Guest
Posts: n/a
Re: WTF! My test pipe CEL just went away yesterday (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">it will come back . it resets it self after some time. Mine did that a few times when i was obd2</TD></TR></TABLE>
after a certain time you turn the ignition the CEL goes off
Re: WTF! My test pipe CEL just went away yesterday (Rocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks »</TD></TR><TR><TD CLASS="quote">
after a certain time you turn the ignition the CEL goes off</TD></TR></TABLE>
right on
right on
Re: WTF! My test pipe CEL just went away yesterday (SOHC_MShue)
Yes it's in the exhaust flow, and yes I'll be going Uberdata in the spring
Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian »</TD></TR><TR><TD CLASS="quote">who's doin your ECU?</TD></TR></TABLE>
Not sure, probably a buddy of mine who chips ECUs all the time. Why?
09-02-2004 04:56 PM
