best engine swap for a del sol to produce the most power.
Old Oct 20, 2004 | 09:52 PM
delsold16's Avatar
Default best engine swap for a del sol to produce the most power.
pretty much i was wondering what the most power i could get out of my del sol with an engine swap, and what engine would produce that power.
Old Oct 20, 2004 | 10:25 PM
91civicDXdude's Avatar
10,000 horsepower. 454 big block supercharged with nitrous bored & stroked ran on nitromethane
Old Oct 20, 2004 | 10:29 PM
Luserkid's Avatar
Default Re: (91civicDXdude)
Put about 15grand from overnight parts from japan and your set.
Old Oct 20, 2004 | 11:05 PM
ZacCarter's Avatar
it all depends on you budget...
low...d series vtec or ls or b20
mid...b series vtec
unlimited....crazy setup with turbo and ****...
I'm in the same exact delima, im prolly just gonna do a b20. No replacement for displacement.
Old Oct 20, 2004 | 11:46 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (ZacCarter)
it really depends on what kind of budget you have and how technical you want to get.
any b-series will bolt right in with no hassle. if you want to get technical and have the money to blow then go for an H22 or even a K20 swap.
Old Oct 21, 2004 | 02:07 PM
Plan B-16's Avatar
Default Re: best engine swap for a del sol to produce the most power. (delsold16)
If you can get it/afford it, the K series has a kit that will drop right in. Otherwise go b18 and sleeve it to 84mm and rock that 2liter for all its worth. Durability and power with the block done right.
Old Oct 21, 2004 | 02:09 PM
Ricey McRicerton's Avatar
Default Re: best engine swap for a del sol to produce the most power. (bshepherd13)
https://honda-tech.com/zerothread?id=878010
shady3260
Jul 24, 2010 06:00 AM
zackhaydon
12
Jul 1, 2009 12:09 PM
ilovejdm
May 23, 2006 04:26 AM
gshockbreaker
Apr 28, 2002 10:16 AM
LLZuB
Mar 18, 2002 06:20 AM
