best engine swap for a del sol to produce the most power.
pretty much i was wondering what the most power i could get out of my del sol with an engine swap, and what engine would produce that power.
it all depends on you budget...
low...d series vtec or ls or b20
mid...b series vtec
unlimited....crazy setup with turbo and ****...
I'm in the same exact delima, im prolly just gonna do a b20. No replacement for displacement.
mid...b series vtec
TSPeed Factory
Re: (ZacCarter)
it really depends on what kind of budget you have and how technical you want to get.
any b-series will bolt right in with no hassle. if you want to get technical and have the money to blow then go for an H22 or even a K20 swap.
Re: best engine swap for a del sol to produce the most power. (delsold16)
If you can get it/afford it, the K series has a kit that will drop right in. Otherwise go b18 and sleeve it to 84mm and rock that 2liter for all its worth. Durability and power with the block done right.
Re: best engine swap for a del sol to produce the most power. (bshepherd13)
shady3260
07-24-2010 06:00 AM
