Welding wastegate on cast iron mani or o2 how to?
Old Oct 20, 2004 | 09:04 PM
DsMWookie's Avatar
Default Welding wastegate on cast iron mani or o2 how to?
I am wanting to have my external wastegate put on the runner on my cast iron turbo manifold or on my o2 housing......
I've heard it is a pain to weld on cast thats why I ask. Can a flange be welded on the cast ?
My other question is my old roomate has a CNC machine and complete machine shop I know he can make the flange or tap the manifold for external wastegate but how will he make the surface flat to mate to the wastegate?
Old Oct 20, 2004 | 10:04 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Welding wastegate on cast iron mani or o2 how to? (DsMWookie)
yes shouldn't be a problem to weld the flange. the key is to torch the cast before you weld...preheat, weld, and post heat. i've welded turbo flange for manifold/turbo conversions and also have converted internal gated manifolds to external. any more ?'s just ask.
Old Oct 20, 2004 | 11:35 PM
DsMWookie's Avatar
Default Re: Welding wastegate on cast iron mani or o2 how to? (not so civic)
My buddy is doing the welding and what not and I just didnt know if he knew how to do it or felt like it......
Old Oct 21, 2004 | 10:24 AM
markdman's Avatar
its easy. like said above, preheat and let it cool on its own. do not quench it, it will crack.
Old Oct 21, 2004 | 10:47 AM
legendboy's Avatar
Default Re: (markdman)
I've mig welded the same thing your doing a couple times with no problems. No preheat required. Just nice welds.
I just bought some special copper based rod for tig welding steel to cast iron.
Old Oct 21, 2004 | 03:27 PM
Brandon Clifton's Avatar
Default Re: (legendboy)
The best thing I've found is Hastelloy W tig wire. It'll stick about anything together.
95civhb
Feb 27, 2010 11:40 AM
Acura_I-RS
Apr 18, 2005 09:23 AM
slooogsr
Nov 5, 2003 02:59 PM
Yani
Oct 23, 2003 10:51 PM
Slater
Dec 31, 2002 07:43 PM
