Is it the clutch?
Old Oct 20, 2004 | 07:35 PM
turbotime's Avatar
Default Is it the clutch?
Ok as some of you may know i got a b17a1 engine slowly being prepped to swap in over thanksgiving break....
Now when I bought the engine it ran fine but the clutch would not go into gear,
Is there a way to tell if the clutch is bad? Or is this a dead givewaway of a dead clutch?
Like if my mechanic took it apart could he say for sure if the clutch is good/bad?
Old Oct 20, 2004 | 07:38 PM
bgoetz's Avatar
Default Re: Is it the clutch? (turbotime)
clutch would not go into gear??? do you mean the clutch would not disengage our the transmission would not go into gear??
Old Oct 20, 2004 | 07:46 PM
turbotime's Avatar
yeah i mean the tranny wouldnt go into gear, the car would start tho... so maybe it isnt the clutch?
Old Oct 20, 2004 | 07:50 PM
bgoetz's Avatar
Default Re: (turbotime)
does it grind when you try to put it in gear???
Old Oct 20, 2004 | 07:54 PM
bgoetz's Avatar
Default Re: (bgoetz)
a bad clutch would just slip. did you put the troughout bearing in right and check the pressure plate to be sure everything is to spec. also did you tighten the pressure plate to the touque spec (I think 19lbs?) Is the clutch pedal firm
Old Oct 20, 2004 | 08:26 PM
turbotime's Avatar
ahh gowd i wish i knew the answers to all these questions...
the engine isnt in a car, it is slated to be put in my car over turkey break..
All i know is the guy i bought it from said that it wouldnt go into gear, he wasnt sure if it was a tranny or clutch problem
I am just trying to figure out if i need to shell out $$ for a new clutch, since i think this already has a stage 1 with flywheel but i dunno if its good to run with or not
Old Oct 20, 2004 | 08:53 PM
Street Ghost's Avatar
Since the motor isn't even in the car.. why not just pull the tranny off and take a look at the clutch, flywheel, and throwout bearing.
Old Oct 20, 2004 | 08:55 PM
DJ_SaNdOz's Avatar
Default Re: (_Project EJOne)
Or, make sure that his problem wasn't a bent/broken fork.
Old Oct 20, 2004 | 08:58 PM
turbotime's Avatar
well we are gonna but im only going to have a week to get the engine in and workin before i need to drive it back up to NY.
If the clutch is fine then there is no problem, well take it apart, look at it and everything is good. But if the clutch is bad then we have to worry about buying/ordering/recieving installing a clutch and i dunno if we'll have time in the week for that
Old Oct 20, 2004 | 09:05 PM
DJ_SaNdOz's Avatar
If you have the cash, I'd suggest putting in a new clutch/bearings regardless. It's a lot easier w/ everything out of the car.
Old Oct 20, 2004 | 09:07 PM
turbotime's Avatar
has anyone ever heard of a gripforce clutch? are they any good? they are pretty cheap $$ wise....
Old Oct 21, 2004 | 03:25 AM
bgoetz's Avatar
I would definatley change the clutch while you have the engine out. You should get a new throughout bearing and pilot bearing (I did with my exedy clutch) change both of these and while you are in there check the shift fork to be sure that it is not bent also check the slave cyl. These are the only things that I think it could be short of serious tranny problems
Old Oct 21, 2004 | 03:27 AM
bgoetz's Avatar
oh yeah can you shift the tranny just by hand moving the lever?? If so I would almost say that it has to be pressure plate, bearing, shift fork related
Old Oct 21, 2004 | 10:18 PM
turbotime's Avatar
i dunno the engine is in MD and im in NY.. anyway im gonna get a new clutch, just for peace of mind if nothing else....
What is the difference between a 3 4 and 6 puck clutch?
I am lookin at an exedy stage 2 with 3 puck....?
Old Oct 22, 2004 | 12:14 AM
HXvtec's Avatar
since the tranny is not in the car that would mean that there isn't any fluid. The only thing I can think of is if there is fluid in the tranny. But again you would have to check this when it's in the car.
lopezchris21
25
Nov 19, 2023 08:24 PM
ksherry
Dec 16, 2010 03:03 PM
hellrsnCL
Aug 10, 2005 08:29 AM
dexy
Jan 10, 2005 10:17 AM
C4wrx
Oct 18, 2002 02:17 PM
