B18B turbo... block guard or deck sealing.. advantages
Old Oct 19, 2004 | 09:24 AM
pane93civhb's Avatar
Default B18B turbo... block guard or deck sealing.. advantages
i was wondering if im going to boost my engine soon. i want to be able to push up to 15lbs of boost at least when im at the track. on stock internals. how much would doing this to the block before i do so benefit me. if everything else in the engine is stock. will i be able to handle this or is it imperative to do this to the block.
also up for any other suggestions on how to make my engine more capable of taking boost and not messing anything up. i would like to still have this car as a daily driver if possible.
Old Oct 19, 2004 | 10:48 AM
Default Re: B18B turbo... block guard or deck sealing.. advantages (pane93civhb)
bump for some help im sure someone knows.
Old Oct 19, 2004 | 11:02 PM
PrettyLude's Avatar
15 psi on a stock block is pushing it, i've seen people on the board do it, but its just a question of how long it will last, even with a great conservative, eventually it will lead done the same road
Old Oct 19, 2004 | 11:31 PM
BEEYOND's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if im going to boost my engine soon. i want to be able to push up to 15lbs of boost at least when im at the track. on stock internals. how much would doing this to the block before i do so benefit me. if everything else in the engine is stock. will i be able to handle this or is it imperative to do this to the block.
also up for any other suggestions on how to make my engine more capable of taking boost and not messing anything up. i would like to still have this car as a daily driver if possible.</TD></TR></TABLE>
good luck with the blockgaurd.......
15psi is doable.....just taking a chance bro.....all up to you!!!
seen 6psi blow fully tuned car...seen 15psi oem engine run for months and months w/o problems.....hey it's racing!!!
Old Oct 20, 2004 | 02:33 AM
97hb's Avatar
14.3lbs of BOOST. Completely stock block LS. 300whp.
Old Oct 20, 2004 | 05:29 AM
GDM Z28's Avatar
Default Re: B18B turbo... block guard or deck sealing.. advantages (97hb)
dont listen to what people say...hell one person may have a t25 and run 20psi of boost and tell you its ok and you do it on your 60-1 and blow it up. I had a t3/t04e 60 trim and ran 14.5psi on the dyno and made 304whp and 270wtq. When i would go out and run people i would run 17psi for a run or 2. It can be done...but it is pushing it. But when i did it i use to just think "hell LS's are a dime a dozen". Remember.....your not fast unless your breaking stuff
Old Oct 20, 2004 | 09:59 AM
Default Re: B18B turbo... block guard or deck sealing.. advantages (civicflnum1)
what type of ecu or management system are u using. im getting an s-afc with the kit i have heard bad things about it though. so im kinda worried i want to be able to push at least 10lbs of boost on it though.. and i will try to get it dyno tuned as soon as possible.
Old Oct 20, 2004 | 01:27 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">what type of ecu or management system are u using. im getting an s-afc with the kit i have heard bad things about it though. so im kinda worried i want to be able to push at least 10lbs of boost on it though.. and i will try to get it dyno tuned as soon as possible. </TD></TR></TABLE>
I run uberdata...its like hondata but free. I HATE the hack because you cant control timing and i hate 450's. If you wana use the hack get a msd btm unit to retard timing. It wont be the best but it will be safer. BTW sell the hack and just pay someone to tune your uberdata!
Old Oct 20, 2004 | 01:46 PM
i dont no how to get uberdata and anything about it but im willing to learn. so i will search for threads about it in and out of site. if u have any helpful hints im all for it though.
Old Oct 20, 2004 | 03:59 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">i dont no how to get uberdata and anything about it but im willing to learn. so i will search for threads about it in and out of site. if u have any helpful hints im all for it though. </TD></TR></TABLE>
im glad to hear you wana learn...check out uberdats site at http://www.ecimulti.org/uberdata/
also look into chrome its the same thing and i hear the newest version kicks ***
Old Oct 22, 2004 | 03:00 PM
cool dude that sounds great ima check that out and see what i can learn.
Old Oct 22, 2004 | 03:05 PM
sp0onfed's Avatar
yah jus make sure ur car is tuned right i melted 3 piston on my b18b with only 11 lbs but it was fun while it lasted
Old Oct 22, 2004 | 03:55 PM
GDM Z28's Avatar
Default Re: B18B turbo... block guard or deck sealing.. advantages (sp0onfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp0onfed &raquo;</TD></TR><TR><TD CLASS="quote">yah jus make sure ur car is tuned right i melted 3 piston on my b18b with only 11 lbs but it was fun while it lasted</TD></TR></TABLE>
sounds like you were running too much timing.....what ems were you on?
Old Oct 24, 2004 | 10:36 PM
sp0onfed's Avatar
i was running a 14 degrees
Old Oct 24, 2004 | 10:44 PM
B18C1CYA's Avatar
if you are going to stay on stock internals, i would get a cometic thicker than stock head gasket and head studs, and get a 255lph intank pump and 450,s and a realy good tune from a good tuner that knows what they are doing, but i would go about 300whp on a stock motor, boost is not what kills a motor it is detination.
Old Oct 25, 2004 | 04:26 AM
menkio's Avatar
Default Re: B18B turbo... block guard or deck sealing.. advantages (B18C1CYA)
.. why are you people talking.
WHAT TURBO... WHAT MANGAMENT
97grnrs
Jan 6, 2008 07:07 PM
Boostin_GSR
Apr 4, 2007 12:21 AM
Targa4Life
Apr 7, 2005 08:57 AM
sPaRk'iT
Jun 12, 2004 11:19 PM
Hoodwinked
Sep 1, 2003 10:07 AM
