rear brake problem-help!!
Old Oct 18, 2004 | 04:37 AM
GUNNER666's Avatar
Default rear brake problem-help!!
it seems whenever i come to a stop all i can hear and feel from what seems to be the back brakes is a thunking type noise, almost like the brake wants to stick to a certain spot on the drum.
what is causing this?
Old Oct 18, 2004 | 11:27 AM
GUNNER666's Avatar
Default Re: rear brake problem-help!! (GUNNER666)
anyone?
Old Oct 18, 2004 | 11:32 AM
sohcvtec1995's Avatar
s in. I had the same problem and one of the bolts was missing
Old Oct 18, 2004 | 12:05 PM
TallAssFilipino's Avatar
Remove the drum-cover and visually inspect it. It's not hard to take off at all. Use a common screwdriver and pry it out, side to side. Or take two 8mm bolts and screw them into them 2 threaded holes to push the drum-cover outward.
Old Oct 19, 2004 | 06:45 AM
GUNNER666's Avatar
Default Re: rear brake problem-help!! (JDM JNKI)
Sounds good
Hanmin
Sep 30, 2010 10:32 AM
joelmatt89
11
Mar 9, 2009 05:30 PM
LsHoney84
Sep 8, 2007 08:58 AM
Seatown
Oct 1, 2006 04:01 PM
integraGSR213
Mar 15, 2004 03:11 PM
