rear brake problem-help!!
it seems whenever i come to a stop all i can hear and feel from what seems to be the back brakes is a thunking type noise, almost like the brake wants to stick to a certain spot on the drum.
what is causing this?
Re: rear brake problem-help!! (GUNNER666)
Remove the drum-cover and visually inspect it. It's not hard to take off at all. Use a common screwdriver and pry it out, side to side. Or take two 8mm bolts and screw them into them 2 threaded holes to push the drum-cover outward.
joelmatt89
11
03-09-2009 05:30 PM
