codes 3 14 and 22 throwin help me out guys
Old Oct 17, 2004 | 09:20 PM
mattcivic's Avatar
Default codes 3 14 and 22 throwin help me out guys
okay just swapped an lsvtec b18a with 00 si head into my 94 ls integra. i know that 3 is the map sensor changed it with spare one still throws the code. 14???? dont even know what it is and or how to fix it help. now ive got 22 showin too i know its either vtec sloenoid or switch. i think i might have put it in the wrong pin not 100% where does it go and make it simple i dont understand that plug C pin # crap so tell me in idiot tems which pin it is or a pic would be nice thanx guys any help would be great
Old Oct 18, 2004 | 03:09 AM
hondaguyef's Avatar
Default Re: codes 3 14 and 22 throwin help me out guys (mattcivic)
14 = IAC (idle air control valve)
22=VTEC pressure switch
I am not sure of the pin on an odb1 ecu but, on an obd0 it's B5. I'm not sure if that will help.
Phil
Old Oct 18, 2004 | 05:21 AM
mattcivic's Avatar
hhmm anyone else know where the presure wire is leading to the ecu on an obd1 set up? thanx
Old Oct 18, 2004 | 06:19 AM
JimBlake's Avatar
On my '95 GSR the VTEC pressure switch is wired to D6 (blue/black). The other wire of the VTEC pressure switch is grounded at the T-stat housing.
Swap'DShuttle
10
Aug 12, 2012 02:35 AM
prime-R
16
Apr 11, 2009 05:33 PM
9WON4
Jun 2, 2006 06:11 PM
lshatch92
Mar 27, 2006 10:04 AM
tinkerbell
Jan 1, 2005 08:00 PM
