timing is off need help in maryland
Old Oct 17, 2004 | 05:49 PM
hondanamics's Avatar
Default timing is off need help in maryland
timing is off so car wont start need someone near laurel jessup savage are to help will pay good. sooner the better email me at hondanamics@msn.com
Old Oct 17, 2004 | 06:32 PM
fknslmd's Avatar
why is your timing off, what did you do?
Old Oct 18, 2004 | 05:53 PM
Default Re: (fknslmd)
i took the belt off i was goin to replace head gasket but couldnt get the head off. i thought i had it all lined up but i guess not can ne on ehelp me please asap will buy lunch or dinner all drinks and gas money plus labor
Old Oct 18, 2004 | 06:40 PM
PrettyLude's Avatar
hear is a long shot, did u have the cam gear 180 degrees off?
Old Oct 18, 2004 | 07:25 PM
Default Re: (PrettyLude)
its possiable but im tired of tryn to fix it just wanna find some one to fix will pay good
Old Oct 19, 2004 | 07:07 AM
JimBlake's Avatar
How can you possibly have a camshaft 180 degrees off? (Think about it...)
Old Oct 19, 2004 | 08:49 AM
James's Avatar
Default Re: (JimBlake)
what year is it?
Old Oct 19, 2004 | 12:17 PM
jweller's Avatar
Default Re: (James)
I'll assume you weren't going to replace the headgasket just because it seemed like a fun way to spend a saturday, so, wtf is wrong with it? and do you think that might have something to do with it not starting?
and how far did you go with pulling the head off before you stopped? could your distributor be off 180? did you maybe forget to reconnect a ground wire somewhere?
and what car is it?
Old Oct 19, 2004 | 05:30 PM
Default Re: (jweller)
91 accord lx never got the head off. ive checkd and rechecked everything just cant figure it out. it ran before this but wont start now ne one help
Old Oct 21, 2004 | 05:50 PM
Default Re: (hondanamics)
on the distibutor theres a bolt for adjustment should the dis be all the way forward. if not where should it be please help
Old Oct 22, 2004 | 04:02 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondanamics &raquo;</TD></TR><TR><TD CLASS="quote">on the distibutor theres a bolt for adjustment</TD></TR></TABLE>I thought we were talking about camshaft timing... That's all about lining up the marks on the crankshaft & camshaft drive sprockets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondanamics &raquo;</TD></TR><TR><TD CLASS="quote">... should the dis be all the way forward. if not where should it be please help</TD></TR></TABLE>You need a timing light to adjust spark timing.
Old Oct 24, 2004 | 04:57 PM
i had some one come by and look at my car they said theres no spark can ne one help on what could be the problem
Old Oct 25, 2004 | 12:35 PM
jweller's Avatar
check all your grounds.
Old Oct 25, 2004 | 12:54 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondanamics &raquo;</TD></TR><TR><TD CLASS="quote">i had some one come by and look at my car they said theres no spark can ne one help on what could be the problem</TD></TR></TABLE>Now that can be lots of things (including grounds)...
The starter cranks the engine, right?
Does the check-engine light turn on when you first turn on the key?
Spark plug wires back on the right order?
Anything disconnected - not only grounds?
Old Oct 26, 2004 | 05:50 PM
as far as i know the wires are in the correct order 1342 1 is at the bottom right. the only wire i found that was loose was the thermostat ground hook it up and still no start. it cranks and gets gas but no spark
Old Oct 27, 2004 | 03:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondanamics &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know the wires are in the correct order 1342...</TD></TR></TABLE>Actually, if they were in the wrong order, they'd still spark... but it would be sparking at the wrong plug at the wrong time so it won't start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondanamics &raquo;</TD></TR><TR><TD CLASS="quote">... it cranks and gets gas but no spark.</TD></TR></TABLE>Do you know whether the injectors are firing? Or do you just mean there's pressure & flow in the fuel rail? You can smell fuel at the tailpipe, or pull a spark plug right after cranking.
If the injectors are actually firing, then the CYP, TDC, etc... sensors in the distributor must be working OK. That's good to know...
Old Oct 27, 2004 | 06:16 AM
alb_accord's Avatar
whats up man. check at cb7tunner. there are about 7 guys in meryland. we gona meet there on november 7. so ask there if someone could come down where u are and help uout.
Old Nov 9, 2004 | 12:25 AM
hurleysurf24's Avatar
Anyone know Sam Windsor?
https://honda-tech.com/zero...age=1
Pass him this message
"Your being a little *** now
Why arent you returning the calls or emails? Better yet, Dont show up for the court date Sam. You will be acquired by the Local PD and then forced to either pay me my money or forced to to community service to pay the fines off. Oh did I mention the lawsuit is upped to 5000 dollars now? Hope you or your mom is rich. Otherwise im going to have some nice souveniers, like everything you own Sam. Ill probably just take your hatch and saw zall it then part it out on ebay.
You will not win Sam. Stop messin around and give me my money. NOW
You know where to reach me"
88EDHatch
11
Feb 3, 2010 04:42 PM
95civicLS
Sep 25, 2008 06:59 AM
kabooki
Jul 19, 2005 09:25 PM
O RLY
Mar 26, 2005 08:36 PM
TurboedGSR
Aug 24, 2002 06:10 PM
