is it bad to have my BOV vacuum hooked to my compressor nipple!
Old Oct 11, 2004 | 09:30 AM
s1ngle's Avatar
Default is it bad to have my BOV vacuum hooked to my compressor nipple!
yes or no, as the title says, and why. thanks!
Old Oct 11, 2004 | 09:43 AM
SOHC_MShue's Avatar
Default Re: is it bad to have my BOV vacuum hooked to my compressor nipple! (s1ngle)
the intake manifold is always the best place to hook stuff like that up to. Pressure usually drops when air goes through the intercooler so its not a good reading because its before the intercooler.
Old Oct 11, 2004 | 09:51 AM
tgreaves's Avatar
Default Re: is it bad to have my BOV vacuum hooked to my compressor nipple! (SOHC_MShue)
Well you want the BOV to be hooked to your intake since when you let off the gas there will be a drop in pressure in it and it will help to pull the BOV open along with the boost pushing the BOV open..
Old Oct 11, 2004 | 10:00 AM
5.0killa's Avatar
Default Re: is it bad to have my BOV vacuum hooked to my compressor nipple! (tgreaves)
hook it up to the intake manifold cause the valve needs vac. to open and there isnt any vac at the turbo.
Old Oct 11, 2004 | 10:02 AM
tgreaves's Avatar
Default Re: is it bad to have my BOV vacuum hooked to my compressor nipple! (5.0killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5.0killa &raquo;</TD></TR><TR><TD CLASS="quote">hook it up to the intake manifold cause the valve needs vac. to open and there isnt any vac at the turbo.</TD></TR></TABLE>
Yes.. I will still kinda open if its not hooked up but for sure its not going to work at all if its hooked to the fitting on the compressor housing..
Old Oct 11, 2004 | 10:17 AM
fsp31's Avatar
edit: I misread your post. Sorry.
Old Oct 11, 2004 | 10:21 AM
5.0killa's Avatar
Default Re: is it bad to have my BOV vacuum hooked to my compressor nipple! (fsp31)
the port on the compressor is for the wastegate tie off of the line that you would hook your boost gauge up to.
Old Oct 11, 2004 | 11:02 AM
djwest24's Avatar
the purpose of the blow off valve or a by-pass valve is to bleed or recirculate excess pressure when ur throttle plate closes, so that it doesnt back up to the compressor, which is bad obviously. and it'll work only if the line is tapped after the throttle body, so that it'll sense vaccum (like 5.0killa said) once the throttle plate closes. so it doesnt do any good if its hooked to your compressor.
i would recommed teeing off of the fpr.
Old Oct 11, 2004 | 11:04 AM
*Boostwerks*'s Avatar
Simply put:
The nipple on the compressor never sees vaccum.
What opens a BOV? thats right...vaccum.
Old Oct 11, 2004 | 02:34 PM
s1ngle's Avatar
Default Re: (Bryson)
interesting... that may explain why my BOV is making a "ch ch ch ch ch" sounds instead of a "psssssssh" sound.
But its still opening to some degree right? i havent blown my turbo have i? is running without a fully functioning BOV really bad?
Old Oct 11, 2004 | 02:39 PM
Default Re: (s1ngle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s1ngle &raquo;</TD></TR><TR><TD CLASS="quote">interesting... that may explain why my BOV is making a "ch ch ch ch ch" sounds instead of a "psssssssh" sound.
But its still opening to some degree right? i havent blown my turbo have i? is running without a fully functioning BOV really bad?</TD></TR></TABLE>
Well its opening because the pressure of the intake plumbing skyrockets once the TB is snapped shut forcing the valve to open. It is deifinetly bad for the turbo, but just change it ASAP.
Old Oct 11, 2004 | 02:59 PM
s1ngle's Avatar
dangit, my turbo has been leaking a bit of oil, i'm guessing its because the excess pressure has blown my seals. could this be the case?
Old Oct 11, 2004 | 03:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s1ngle &raquo;</TD></TR><TR><TD CLASS="quote">dangit, my turbo has been leaking a bit of oil, i'm guessing its because the excess pressure has blown my seals. could this be the case?
Its defintely a possibility, but normally leaking oil seals are due to an inadaquate drain line.
Old Oct 11, 2004 | 04:38 PM
s1ngle's Avatar
crap. i bet i did mess my turbo up. my drain is perfect, can't be the reason. But how is that any different than simply having a BOV made for more boost?
Old Oct 11, 2004 | 04:49 PM
s1ngle's Avatar
i mean, if it was just putting a lot of stress on the turbo causing it to leak, would the oil leak now go away if i take that stress away? or am i screwed?
Old Oct 11, 2004 | 05:32 PM
XSIintegra's Avatar
depends on the level of damage caused. Who knows what kind of boost pressure its being slammed into when your TB closes. Incredibly hard on the compressor itself. If the seals are blown, they will not reseal. If the damage is minimal...u may get away with it
Old Oct 11, 2004 | 06:00 PM
s1ngle's Avatar
Default Re: (XSIintegra)
gar, i guess i'm just super worried right now. the turbo still spins great, almost no shaft play, so even if the leak continues i'll just deal with it for a while.
on a side note, is tehre any good place to JUST get the oil seals?
Old Oct 11, 2004 | 07:22 PM
egturbo's Avatar
lol the ch ch ch is turbo surge
Old Oct 11, 2004 | 07:28 PM
s1ngle's Avatar
Default Re: (egturbo)
crap, that sucks, i did hear a silvia that made the same sound though....
Old Oct 11, 2004 | 08:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s1ngle &raquo;</TD></TR><TR><TD CLASS="quote"> crap, that sucks, i did hear a silvia that made the same sound though....</TD></TR></TABLE>
Some BOVs will make that sound under low boost because they have a high tension spring(the Tial for example).
Vagitarian
Jan 2, 2013 06:47 PM
superslow-oto
Nov 6, 2007 02:42 PM
R6E6I6D
Dec 4, 2005 11:58 AM
turtle-eg
Apr 26, 2004 05:14 PM
echo999
May 14, 2002 08:54 PM
