b20 turbo
Old Oct 9, 2004 | 07:23 PM
majek's Avatar
Default b20 turbo
I was wondering because I am going to be buying a dart block but not sure which one yet. I have a b16 head ready to go on a b20 dart block or a b18 dart block, I,m going to be getting 9:1 pistons for what ever block I pick, but I need some opinons on what setup would be better for runnig about 10psi daily driven. PLEASE LEAVE ME YOUR OPINION. THANKS I was leaning problaby more towards the b20
Old Oct 9, 2004 | 07:34 PM
Chip's Avatar
Default Re: b20 turbo (majek)
10 psi daily driven, and you're thinking of dropping 2 grand on a dart block? Are you insane?
Old Oct 9, 2004 | 07:48 PM
majek's Avatar
I meant 10psi daily driven and about 20psi at the tracks.
Old Oct 9, 2004 | 07:57 PM
dornon13's Avatar
If i had a dart block id prolly run 20psi everyday haha
Old Oct 9, 2004 | 09:16 PM
please.laugh's Avatar
i tohught all dart blocks were the same... the only difference between the blocks are deck height, and dart has a special stacked deck... correct me if i'm wrong?
btw-that block with some nice forged pistons would handle 10psi all day every day. Its not a matter of brand name when your block is so storng. any forged piston and rod combo will do fine. Low comp and high boost, 1 bar daily driven on a strong motor isn't a problem.
Old Oct 10, 2004 | 12:31 PM
majek's Avatar
Default Re: b20 turbo (please.laugh)
I also whanted to know what parts of the b-series are interchangeable? I have the b16a2 block and wanted to know if I could put the water pump, oil pump, belt tensioner, and oil pan onto the dart b18c or b20 block. I still need opinions on which block I should get. But I just wanted to know what parts can fit on the b18c or b20 from my b16a2 block.
Old Oct 10, 2004 | 01:03 PM
majek's Avatar
Oh and what headgasket do I need to use, if I get the b20 Iwould need to use a b20 headgasket or if I get the b18c I would need to use the b18c headgasket.
Old Oct 10, 2004 | 08:07 PM
majek's Avatar
anyone
Old Oct 11, 2004 | 01:21 PM
majek's Avatar
please I need someones opinion so that i can make up my mind.
Old Oct 11, 2004 | 01:26 PM
boosted eg's Avatar
hey man i can help i owned one all b-series parts are interchangable just make sure u dont get the tall deck one thats were i screwed up
Old Oct 11, 2004 | 02:52 PM
rintegration24's Avatar
Theres no replacement for displacement...2.0L turbo Hondas are sweet on the street but If I were you, I would be maxing that thing out 15-18psi on pump gas, 30+ at the track providing your fuel system can handle it. I assume any Dart block can handle the power.
Old Oct 14, 2004 | 02:49 PM
majek's Avatar
So all b-series parts are interchangeable right and the only difference between the b18 and b29 is the deck height and the bore so if I were to get the b20 dart block would it have more power than the b18 at the same psi and same compression pistons because of its displacement.
j_civic
Engine Management and Tuning
Mar 26, 2009 09:58 AM
Ct4754
Oct 11, 2008 06:24 PM
lakai_19
May 21, 2007 02:25 PM
BrOkEn_Dc2
Apr 9, 2006 03:50 PM
Rice Is Best
Dec 26, 2004 08:10 PM
