93 civic ex problem.
Old Oct 8, 2004 | 11:11 PM
MEATWAD_00GT's Avatar
Default 93 civic ex problem.
First off this is a friends car but ive worked on hondas before so im pretty familiar with them, the prop them is the seedometer isnt working. I made a quick glace at 12am with a flash light and didnt see anything un hooked. But yeah its a 93 ex. She just bought it and it has some mods done to it. I think a new motor was put in it, it said D16 and them some numbers i forgot. What came in these stock? Back to the speedometer question, what should i check? Dont hate on my fr being a V8 guy lol well thanks for any help!
Old Oct 8, 2004 | 11:13 PM
IWearMyKswiss's Avatar
New User
Default Re: 93 civic ex problem. (MEATWAD_00GT)
is she throwing a check engine light? it could be the Vehicle speed sensor,..the VSS wiring,..or the gauge cluster
Old Oct 8, 2004 | 11:15 PM
Kendall's Avatar
Default Re: 93 civic ex problem. (2.0 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0 EK &raquo;</TD></TR><TR><TD CLASS="quote">is she throwing a check engine light? it could be the Vehicle speed sensor,..the VSS wiring,..or the gauge cluster </TD></TR></TABLE>
Make sure that your getting continuity to the VSS, if you're not then check the wiring before replacing the sensor.
Old Oct 9, 2004 | 02:05 PM
Default Re: 93 civic ex problem. (Kendall)
Ok thanks guys ill besure to check that.
Old Oct 9, 2004 | 05:56 PM
bumop
Old Oct 9, 2004 | 06:07 PM
Street Ghost's Avatar
Check the Vehicle Speed Sensor.
Also, a 1993 Civic EX comes with a D16Z6 motor, stock.
Old Oct 9, 2004 | 11:28 PM
Default Re: 93 civic ex problem. (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja &raquo;</TD></TR><TR><TD CLASS="quote">Check the Vehicle Speed Sensor.
Also, a 1993 Civic EX comes with a D16Z6 motor, stock.</TD></TR></TABLE> Ok well i think it said D16something8 i remember there being a 8. Looked to be a swap becasue of the writing on the valve cover.
Old Oct 9, 2004 | 11:48 PM
murmur9's Avatar
its probably the vss, the motor that she probably had swapped if it says d16 something 8 is most likely a D16Y8 SOHC VTEC from a 96-00 civic ex
Old Oct 10, 2004 | 02:08 PM
Default Re: 93 civic ex problem. (murmur9)
Yes it a SOHC VTEC and i beleive thats the number on the block. How would i check for the VSS?
Old Oct 11, 2004 | 08:40 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
where is the VSS located ?? my speedo isnt workin either , and my rpms work a lil its goes up to 4k and restarts again from 1
White93civiclx
Aug 28, 2014 10:00 PM
sk8kingda3rd
Jun 24, 2009 10:57 AM
wtaylor70
Aug 11, 2005 12:49 PM
KPizzle
May 31, 2004 08:14 PM
dash80
12
Sep 24, 2003 08:42 AM
