dizzy is fired sooo!!!!
ok what dizzy works with a jdm d15b motor ..so i can get one asap ..my car cranks but no start..changed plugs, no smoke ..so i know its the dizzy
usually the first thing to go in the distributor is the coil,...a bseries coil from my local autoparts store ran me around 60 bucks,..might be cheaper for a dseries,..i would try getting a new coil first,..cheaper than getting a new distributor,...btw how are you checking for spark?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 »</TD></TR><TR><TD CLASS="quote">im checking it buy putting a screw driver in the wires</TD></TR></TABLE>
take a spark plug out,...now put it in the boot of the sparkplug wire,..hold it like an 1/8 of an inch away from a good ground,..have a friend turn the key to crank the motor,..look in between the spark plug and the ground and see if you can see a spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 »</TD></TR><TR><TD CLASS="quote">ok i'll do that ..if nothin then what</TD></TR></TABLE>
its not a for sure thing but most likely your coil is done because like i said above,..usually the first thing to go is the coil,...go get a new coil from autozone/pepboys/etc
ok cool yeah i was just talk to my friend he said the same thing happen and it mite be my coil so i hope that it.else im screwed
